    Render problem
    renderpluginsextensions
    4 Posts 3 Posters 351 Views 3 Watching
      chamferman
      V Ray Version 1.49.01
      SU 8
      Hello folks
      I am pretty new to v-ray. so find my self on a steep learning curve at the moment πŸ˜• I am loading a flooring vismat into my material editor & then applying to my material selection which is a rectangular surface. The floor proportions look great until i render then they become too small. Could someone tell me what I need to do to stop this happening?
      http://i514.photobucket.com/albums/t342/simuk_2008/Renderedfc.jpg
      http://i514.photobucket.com/albums/t342/simuk_2008/Sufc.jpg
      Thanks in advance
      Simon
      SketchUp 8, V-Ray 1.49.01
      • stefanqS Offline
        stefanq
        Yes, I had this issue in the past. My problem was that the face (surface) was reversed. Use the monochrome style to see if your floor have this problem.
        Cheers!
        • eidam655E Offline
          eidam655
          [questionable]i would say that the moment when a texture is loaded into the vray material editor, it doesn't make sense to edit the texture size in SU Material editor.[/questionable]
          the solution, imho, is to change the u/v repeat values in the TexBitmap slot. (so to make the texture bigger, the repeat number needs to be lower.)
          I'm using SketchUp 2017, V-Ray 3.4
            chamferman
            Cheers!
            Hi thanks for the suggestion already tried this.
            Hello thanks for the quick response, this solved my problem πŸ˜„
