    Unidentified program trying to access...
    11 Posts 5 Posters 1.2k Views 5 Watching
    • brookefoxB Offline
      brookefox
      Windows Vista. When I did the last SU8 upgrade, I failed to do it via right click 'run as admin' and as a result ever since I have had to take the extra step of OK'ing every run of SU. Permissions fully enabled for everyone under the sun. Repair doesn't work so I'm guessing a full uninstall - reinstall is my only choice. I've got the plug folder copied out; any way to save toolbar layout? Any other tips?
      ~ Brooke
      • jeff hammondJ Offline
        jeff hammond
        is it "sketchup wants to use a network connection" or something like that?
        we get this on macs too but theres an 'always allow' option. does an option like that appear in your prompt?
        dotdotdot
          brookefox
          I wish. No, it's "An unidentified program wants to access your computer" with options to allow or not but not to 'always allow'. There's also "user account controls prevent unauthorized use" and "Don't run the program unless you know where it's from or have used it before", but nothing useful. Even though I've run it hundreds of times and know where its from and have specifically given everyone the right to run it and even though it is only I as admin who is attempting to run it it won't let me run it without playing the little distraction.
          Thanks.
          ~ Brooke
            jeff hammond
            ok. I have no clue. 😆
            I shouldn't of even replied in the first place!
            surprised no one else has chimed in yet tho.
            dotdotdot
              mac1
              Have you done a goole search ?? http://www.ehow.com/how_5963073_change-icon-run-administrator-vista.html
                brookefox
                Yes, I've done the search a few times. Thank you. Nothing suggested works.
                ~ Brooke
                  ArCAD-UK
                  When you say "full reinstall" do you mean the O.S? If so go get a copy of Win7! I used to get these problems with Vista and have never had anything similar since I upgraded.
                  I take it you tried reinstalling SU as an Admin? Just not sure from the way I read your post.
                  It's been a while but if you rt-clk the SU icon under properties you may find a setting for "run as administrator".
                    brookefox
                    'Run as admin' does not work for me. I meant re-install SU, not Vista. Apparently Vista is notorious for this issue.
                    Thanks.
                    ~ Brooke
                      mac1
                      Maybe some thing here http://support.microsoft.com/kb/922708.
                      • mitcorbM Offline
                        mitcorb
                        Maybe if TIG noticed this discussion... His profile says Vista. He is known to be fairly well versed in computer stuff.
                          brookefox
                          Not as far as I can tell, but thank you.
                          ~ Brooke
