    Organic egg chair help?
    8 Posts 4 Posters 1.3k Views 4 Watching
      dario27
      I've started to model an egg chair thinking it would be easy to make, i was wrong 😐
      I'm having trouble with the two recessed cut outs at the base of the chair, what would be the best way to model these?
      I have the artisan tools but only know enough about them to get myself in trouble.
      http://i1176.photobucket.com/albums/x340/Dario_27/renders/eggchairsketchup.jpg
        It looks like you've got a good start. I'd round over the edge of that box shape to match the radius of the curve on the original. Then run Intersect on the geometry and delete the waste. You'll need to cut that box shape flush with the front of the egg. You could use Push/Pull to push the near end face in to the front of the egg and that should take care of it.
        By the way, I would only model half of this and then copy and flip to make the opposite side.
        • cottyC Offline
          cotty
          With Artisan you can try to start like this...
          eggchair.skp
          my SketchUp gallery
          • fuzzionF Offline
            fuzzion
            lol my lunch time attempt
            "Only the dead have seen the end of war" - Plato
              dario27
              Thanks for the good tips πŸ˜„
              My first attempt was with the boolean cutout, but i think i had too many faces, i'll try again with a simpler model.
              I still need lots more practice with artisan, things never seem to look how i intend them to.
              I'll post again when i've made something that looks better πŸ˜„
              • fuzzionF Offline
                fuzzion
                You can try making model 100x bigger before cutout
                  dario27
                  I had a happy accident with the artisan tools πŸ˜„
                  http://i1176.photobucket.com/albums/x340/Dario_27/renders/ArtisanEgg.jpg
                  Its getting close to what i need now, It just needs a flatter bottom.
                    dario27
                    I finally got the model finished, after 1000 mistakes and 1001 fixes πŸ˜›
                    http://i1176.photobucket.com/albums/x340/Dario_27/renders/eggchairfinished.jpg
