    [plugin] Rotated Box [updated 30-Mar-2014]
    69 Posts 21 Posters 35.2k Views 21 Watching
    • sdmitchS Offline
      sdmitch
      No way to define the axes of a group that I'm aware of.
      You can temporarily align the axes to the group when in group edit mode.
      http://sdmitch.blogspot.com/
        You can [re]set a group's axes...
        Find each of the desired-axes in turn and its angle from the SKP's axes - do the three axes in turn...
        Apply a rotation-transformation to the group's geometry in turn:
        group.entities.transform_entities(transformation, group.entities.to_a)
        to rotate the geometry back to be 'axial'.
        Then immediately apply the inverse transformation to the group itself:
        group.transform!(transformation.inverse)
        • again this must be done once for each axis in turn - so that could be three transformations in all ?
        The group is now as if you made it 'axially' and then rotated it in 3d afterwards.......
          the.pjt
          thanks for new vertion mr. sdmitch .... nice update ... πŸŽ‰
          .. waiting for cylinder plugin too πŸ˜‰
          • sdmitchS Offline
            sdmitch
            TIG, thanks for the info. I guess my next question is what is the advantage or need to do this?
              jorge2011
              sdmitch, when editing a group or component is better to work with the axes perpendicular or parallel to the predominant form (inthis case a square) is simpler drawing
              • sdmitchS Offline
                sdmitch
                I agree so when you get into edit mode, right click on the group and choose Align Axes.
                  jorge2011
                  if I agree, but is simpler if this is automatic
                    Ben Ritter
                    Sam, thank you.
                    • broomstickB Offline
                      broomstick
                      a perfect addition to this tool would be an icon to put along side le rectangle icon.
                      If anybody can teach me, i am willing to do it myself πŸ˜„
                        Michaelv
                        Done, see here:
                        http://forums.sketchucation.com/viewtopic.php?f=323&t=45923
                        • sdmitchS Offline
                          sdmitch
                          Version 1.2 has been posted. It aligns the axes to the box if grouping.
                            the.pjt
                            when we work in a group of group , the box that this plugin makes goes to the model ( upper level in outliner )
                            OUTLINER VIEW
                            model ( the box goes here )
                            .........group 1
                            ..............group 2
                            ....................group 3 ( we want a box here )
                            • sdmitchS Offline
                              sdmitch
                              OUTLINER VIEW
                              .........group 1
                              You may want the box to be part of an existing group but who else will. You can add any box to an existing group by selecting and cutting it then open for edit the group you want to add it to and do a "Paste in Place".
                                the.pjt
                                Mr. sdmitch
                                are you joking ?
                                cut and paste ???? ... thank a lot .... do you think that I didn't know anything about Cut and Paste !?!?!?!? Am I crazy or stupid ?!?!?
                                you could also learn me the basis of SU .. how to make rectangle inside group and then Pushpull !! πŸ˜„ ...
                                ok .... thanks for teaching .... πŸ˜„ ... but please don't consider me as a total mindless and stupid person ...
                                OK ... but, as you know this plugin should be a time saver ...
                                And when a user is working trough a group and/or component it takes shorter time for him/her to create a box with a few clicks inside it .. rather than Cut , Set Axes , Paste Set axes agane ... or Rectangle , Rotate , Pushpul , Select , Make group ....
                                isn't it ??
                                OK ... we will welcome if you do this ... and thanks agane for the time you spent for us and you coddings , dear Sam ... πŸ˜‰
                                • sdmitchS Offline
                                  sdmitch
                                  the.pjt since you are not "a total mindless and stupid person", code it yourself. When this all started, you only wanted a "box in 3 click", now you want me to customize this just for you. Sorry but I'm done with this plugin. I have done all that I ever intend to do.
                                  • kenK Offline
                                    ken
                                    the.pjt
                                    After making a selection of the object you wish to move to another layer, look in the edit menu, and click on the "Cut" menu item. after clicking on the "Cut" menu the object will disappear. Then drill down to the layer you wish. After arriving at your selected layer, in the edit menu click on the "Paste in Place" menu item and presto, you have a copy of the selected object at the new layer. Good solution to moving objects from layer to layer. Much better than Ctrl-C and Ctrl-V.
                                    Ken
                                      the.pjt
                                      I never want you to code for ME .... this is a plugin for all users .. and please don't think that all of your works is for me ...
                                      when somebody used this plugin for making a box inside a group , it makes it out of active group
                                      ... and I thought it's better to tell you " it's better to add this in feature ... "
                                      .. I think you hear : " do it , outher wise I will fire you !!!! " ... ok ..
                                      it's better to say : " sorry , I beleve that it should be fixed ,but I haven't enought time , tell your request to some one else " ... instead of " how to Cut and paste " .. isn't it ?
                                      but ... if you to update it in the future please fix it to makes the box in current group ( for outher users not me )
                                      • sdmitchS Offline
                                        sdmitch
                                        OK, any other users think this is problem or desired feature?
                                          I haven't used the tool, but common convention for tools is to create the entities they create within model.active_entities instead of model.entities. It also allows for the best flexibility. Since it is the convention with the native tools and pretty much all custom tools it is confusing if the geometry is created in a different context.
                                          • brookefoxB Offline
                                            brookefox
                                            From the peanut gallery, if the choice is to create within or outside of the current group, I'd say within would be preferable for me.
                                            Thanks for asking.
                                            ~ Brooke
                                            • 2 / 4
