    How to regular subdivide a shape?
    9 Posts 5 Posters 827 Views 5 Watching
    • L
      lamandrion
      Hello,
      so i have a shape like this:
      http://i.imgur.com/W0ujQ.png
      And it should look like this:
      http://i.imgur.com/gi9Fk.png
      I tried a subdivision tool but it didnยดt work:
      http://i.imgur.com/TzrYb.png
      Is there a plugin that does this ?
      Thank you!
      • GaieusG
        Try this one: http://forums.sketchucation.com/viewtopic.php?t=37719
        • L
          lamandrion
          unfortunatly this didnยดt work for me ๐Ÿ˜ž
          result:
          http://i.imgur.com/xUdbw.png
          But thanks for the idea!
            For Gaieus without Plugins! ๐Ÿ’š (it's a very big effort for me! ๐Ÿ˜‰
            Draw any regular or no regular gride above your form then use the Drape tool of the Sand box
            Then intersect or any function you want ๐Ÿ˜„
            But why not with more simplicity draw a Network of lines on the form then intersect? โ“
            • fuzzionF
              fuzzion
              All subdivisions will triangulate the face. Why do u want squarish portions? You might have to follow the drape method ๐Ÿ˜•
              "Only the dead have seen the end of war" - Plato
              • L
                lamandrion
                actually, triangles would work fine for me.
                I just want to be able to sculpt the ground. I tried subdivision but the triangles are all different sizes... i want them to be all around the same size!
                • fuzzionF
                  fuzzion
                  If you are, and i might be wrong, trying to landscape, use sandbox ๐Ÿ‘Ž (garbage IMO ) or Artisan ๐Ÿ‘ ๐Ÿ‘ (excellent) or even TGI with its construct points ๐Ÿ‘ (so-so for landscaping)
                  ...Perhaps u could describe what exactly you are trying to make. That will help alot
                  • brookefoxB
                    brookefox
                    Try making a 'from scratch' over your shape, then intersect selection after selecting both.
                    ~ Brooke
                    • L
                      lamandrion
                      Thank you very very much!
                      I try to draw a zen garden with small hills. I bought Artisan some time, it is a real help for me ๐Ÿ˜„
                      Thank you all again!
