    NCS Colors?
    3 Posts 3 Posters 2.9k Views 3 Watching
    • M
      mars
      Hi guys,
      Sorry if u already discussed about this issue but i couldnt find anything on search. Is there any way to introduce NCS Colors (or equivlent) in Sketchup? I couldnt find any way by myself.
      Thx alot!
      M
        You can edit any color as needed under the Edit tab in the Materials browser. You can set RGB, HLS or HSB values.
        • TIGT
          This www-site will quickly covert NCS to RGB for you
          http://jsfiddle.net/jdias/b3hEa/
          then you can just use the three RGB values it gives you in the SKP's material-editor to make a new material to match...
          It would be easy enough to incorporate this code into a webdialog and then make the color for you...
          Perhaps some brave scripter might have the time to do it [one day]...
