    Google earth terrain
    9 Posts 5 Posters 1.9k Views 5 Watching
      rhysifan
      hi
      id like to import a google earth terrain into sketchup...
      is this possible in the free sketchup 8?
      thanks
      rhys
        Yes, File > Geo Location > Add Location
        Then choose your location And select Grab
          rhysifan
          thanks for replying,
          that doesnt seem to give the terrain though - its just a flat image...
          is it possible to get the hills etc as a model?
            In your layer pallette the terrain is checked off.
            File > Geo Location > Show Terrain
            or...
            Just enable under the Layers pallette
              Also, there is the Google toolbar under View > toolbars. When you import a terrain (add location), it imports a flat screenshot and a 3D terrain on two separate layers. With the Toggle terrain button, you can toggle between these two layers.
                rhysifan
                brilliant - thank you
                  dlp
                  This looks really simple but I can't get it to work. The Add Location window appears, I navigate to the location I want, I click the Select Region button, adjust the selection box, then click Grab and the selection box disappears but the Add Location window is still there with no options to do anything. When I close the Add Location window there is nothing in Sketchup. I am using Sketchup 8 free for Mac.
                  • wind-borneW Offline
                    wind-borne
                    try info here
                    http://sketchucation.com/forums/viewtopic.php?f=11%26amp;t=55817
                    "To read between the lines was easier than to follow the text."OSX 10.11.6
                    %(#BF80BF)[SU 8 pro
                      dlp
                      Thanks, works now.
