    Texture export issue
    26 Posts 5 Posters 1.8k Views 5 Watching
    • kingsiK
      kingsi
      Hi everyone.
      Quick question. I have a model where I have used the "match colour on screen" option on a material. If I use the "Make Unique Texture" option it reverts back to its original colour. I have tried saving the texture as new, but it basically makes a copy only without grabbing the new colour. It would not normally be a problem, but as I am trying to export the model it is reverting to original material only. Any ideas how I can get round this without using photoshop.
      Many thanks
      Noobtastic
        Could you post the material/color you are trying to match?
        • kingsiK
          kingsi
          Sorry guys I don't think I explained myself very well.
          I have a wood texture that I am using for the side of a house. The original colour of this texture is whitish. The colour of the house is green. I used the eyedropper tool in sketchup materials/edit to grab a colour overlay that converted the whitish texture colour to green. This looks great. The problem only occurs when it comes to exporting whereby the Collado file of the texture does not realise that its supposed to look green. I tried to get around this by using the "make unique texture" but as soon as I do I end up with an area in the original texture colour.
          I am pretty good on photoshop but if I try and colourise the original texture I loose too much of the detail and it looks naff.
          Any cunning ideas?
          Noobtastic
          • GaieusG
            What happens if you right click on the material thumbnail and "export texture image"? Does it come as colorized?
              Have you tried using "Create Material" instead?
              • kingsiK
                kingsi
                Hi Dave
                Yeah that was one of the 1st things I tried. The key problem to be solved is how to in effect flatten the texture (like you would do with filters in a jpeg in photoshop)
                Noobtastic
                • massimoM
                  massimo Moderator
                  If you export the 3d model as collada (DAE) you will have a folder with current textures in your model even if modified.
                  • kingsiK
                    kingsi
                    same problem as before. I am thinking the best way is to render a square with the painted on colour then replace all the sections with the new jPeg
                    Noobtastic
                    • kingsiK
                      kingsi
                      Thats where they are being corrupted (reverted back to original) I can only presume that the export does not take into account the colour overlay I have assigned and therefore just ignores it.
                      Thanks for everyones help by the way πŸ˜„
                      Noobtastic
                      • massimoM
                        massimo Moderator
                        Just tried and it's working here. πŸ˜„
                        • kingsiK
                          kingsi
                          For one second I thought I was going mad. Just check my export folder with textures and it is exactly as I said (original texture without paint) 😠
                          Noobtastic
                            Export and post the material.
                            If you've created a new material, purge the old one from the In Model library. Then the white version shouldn't even be available during the export.
                            • massimoM
                              massimo Moderator
                              I don't have SU8, but I can assure you that in 7.1 it works fine.
                                [off:errubjo7]Why is that?[/off:errubjo7]
                                • massimoM
                                  massimo Moderator
                                  [off:r9dcwdf8]Why I don't have SU8? I don't need to upgrade the pro version and a bit scared about two versions of SU on the same computer (mess)... πŸ˜†[/off:r9dcwdf8]
                                  • kingsiK
                                    kingsi
                                    [xxl-img:2gykvfeb]http://www.langlidesign.com/images/business/colour_in_sketchup.jpg[/xxl-img:2gykvfeb]
                                    Here is a diagram lol of what is going wrong.
                                    Noobtastic
                                      I'd just like the material file. πŸ˜’
                                      Or maybe you don't really want the help.
                                      • GaieusG
                                        Kingsi, you are not making this easy. Post that damn material file - or even better, the whole model! We promise we won't sell it! πŸ˜„
                                        • kingsiK
                                          kingsi
                                          You guys are killing me lol
                                          http://bitshare.com/files/9u7537lg/green-bungalow.rar.html
                                          its a big file so be warned
                                          Noobtastic
                                            How many times do I have to ask? Just the material file. πŸ˜’
                                            I give up. I've wasted too much of my time trying to help you.
                                            • 1 / 2
