    Plug in WELD- hidden geometry?
    10 Posts 4 Posters 776 Views 4 Watching
    • ipsketchpiI Offline
      ipsketchpi
      I have downloaded WELD plug in from SMUSTARD COM. Something close to Auto CAD comand PEDIT (makes poliline). But I have a problem. When I push these surface from these new WELDED perimeter, I have no edges represented in new 3D object- attachement. Why, is there any other plug in to join edges into one poliline and to have these major connecting points retained?
      /IP
      • mitcorbM Offline
        mitcorb
        This is normal behavior for the program. If you have softened edges, use Control+Shift+Eraser tool to harden. Or select the menu command for soften smooth edges and set the slider in the interface to taste. Make your selection first.
        • jeff hammondJ Offline
          jeff hammond
          recurve won't join any lines with an angle greater than one radian..
          http://forums.sketchucation.com/viewtopic.php?t=36822
          it's way better than weld.rb 😉
          dotdotdot
            ipsketchpi
            thanks
            /IP
              The easy fix is to not select edges that you don't want included in the welded polyline.
                jeff hammond
                that's what's sweet about recurve.. you only have to select one edge then use the 'select curve & recurve' option... it will then select all the other appropriate segments automatically and join them.
                dotdotdot
                  ipsketchpi
                  How to do that ? "that's what's sweet about recurve.. you only have to select one edge then use the 'select curve & recurve' option... it will then select all the other appropriate segments automatically and join them." Can you please post printscreen?
                  /IP
                    jeff hammond
                    it's in the right-click context menu.. right click on one of the segments then ---
                    dotdotdot
                      ipsketchpi
                      I do not have such comand. Does it come from some plug in?
                      /IP
                        jeff hammond
                        it's a plugin called recurve...
                        see the third post in this thread. 😉
                        dotdotdot
