⚠️ Libfredo 15.4b | Minor release with bugfixes and improvements Update
Plug in WELD- hidden geometry?
10 Posts 4 Posters 437 Views 4 Watching
  • I Offline
    ipsketchpi
    I have downloaded WELD plug in from SMUSTARD COM. Something close to Auto CAD comand PEDIT (makes poliline). But I have a problem. When I push these surface from these new WELDED perimeter, I have no edges represented in new 3D object- attachement. Why, is there any other plug in to join edges into one poliline and to have these major connecting points retained?
    /IP
      mitcorb
      This is normal behavior for the program. If you have softened edges, use Control+Shift+Eraser tool to harden. Or select the menu command for soften smooth edges and set the slider in the interface to taste. Make your selection first.
        recurve won't join any lines with an angle greater than one radian..
        http://forums.sketchucation.com/viewtopic.php?t=36822
        it's way better than weld.rb 😉
        • I Offline
          ipsketchpi
          thanks
          /IP
            The easy fix is to not select edges that you don't want included in the welded polyline.
              that's what's sweet about recurve.. you only have to select one edge then use the 'select curve & recurve' option... it will then select all the other appropriate segments automatically and join them.
              • I Offline
                ipsketchpi
                How to do that ? "that's what's sweet about recurve.. you only have to select one edge then use the 'select curve & recurve' option... it will then select all the other appropriate segments automatically and join them." Can you please post printscreen?
                /IP
                  it's in the right-click context menu.. right click on one of the segments then ---
                  • I Offline
                    ipsketchpi
                    I do not have such comand. Does it come from some plug in?
                    /IP
                      it's a plugin called recurve...
                      see the third post in this thread. 😉
