    Right click popup on mac when dividing.
    13 Posts 6 Posters 631 Views 6 Watching
      squiddenm
      Hi!
      After I started using SU on mac I seem to be missing the popup when I right click to divide an edge. On windows when you divide an edge you are told the distance of the division. This is very useful - I really miss this little feature on the mac. Anyone but med having having this problem??
      Thx in advance
      Michael
        jeff hammond
        it used to work on mac… it quit working with lion and/or su8 and was never fixed in either of the two su8 maintenance releases..
        bummer because i liked/used/relied on that feature as well..
        πŸ‘Ž
        dotdotdot
          squiddenm
          Jeff thank you for answering my question!
          Let's hope it will be fixed in the next release.
          /michael
            chedda
            Strange mine still works fine with su8 & lion.I am using the mighty (not magic) mouse perhaps that makes a difference ?
            Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
              jeff hammond
              divide still works.. it's just that the popup doesn't.
              for instance, say I have a 48" line then I right click -> divide.
              I used to be able to slide the mouse around and see a popup which would say something like '6 segments @8" ...5segments @ ~9 5/8"... 4segments @ 12"... etc..
              you're saying that still works for you?
              dotdotdot
                mwm5053
                I get the popup window on mine #segments, certain length.
                But a new issue as surfaced with DC components, changeable values are blacked out http://forums.sketchucation.com/viewtopic.php?f=11&t=45382 makes impossible to change cabinet size.
                2011 iMac
                SU 2015 Pro, 2017 Make
                V2 Twilight
                macOS Sierra 10.12.5
                  squiddenm
                  Strange things happened here.
                  Yesterday when i updated my iMac. Lion and SU 8. On this computer the popup surprisingly works. Actually I forgot to check if it worked before I updated, since I normally only work with graphics on my macbook.
                  I tried a reinstall of SU on my macbook without any result...
                  /michael
                    chedda
                    Yes i can confirm the little box with the number of divisions and lengths still appears. I am using a 5870 graphics card perhaps this is an open gl driver issue.
                      jeff hammond
                      weird.. i found the culprit but i can't really figure out how this pref changed (or maybe it was just set this way upon my original su8 install ?? that's about the only thing i can think of… otherwise, i'm pretty sure the only way to change this would be to manually edit the .plist )
                      but all is working fine now.. just took me quite a few months to figure out 😞 πŸ˜•
                      dotdotdot
                        brookefox
                        Jeff (or anyone), what is the Windows equivalent of what your pic shows; is that a preferences screen? Sorry if it is; I'll check it.
                        ~ Brooke
                          jeff hammond
                          i think the windows equivalent is the registry.. on mac, all preferences are stored in a .plist file..
                          and from what i gather, they're much less daunting/scary than visiting the registry πŸ˜‰
                          (but i could be wrong.. i don't even know what the registry is.. i just hear about it from time to time πŸ˜‰ )
                          dotdotdot
                          • G Offline
                            It's a scary thing MS only invented to keep users at bay. πŸ˜•
                              squiddenm
                              Today I updated to 8.0.11751 - on my iMac, the popup stopped 😞 We must ask the Sketchup team about this small but but annoying issue.
                              /michael
