    Right click popup on mac when dividing.
    13 Posts 6 Posters 648 Views 6 Watching
      squiddenm
      Hi!
      After I started using SU on mac I seem to be missing the popup when I right click to divide an edge. On windows when you divide an edge you are told the distance of the division. This is very useful - I really miss this little feature on the mac. Anyone but med having having this problem??
      Thx in advance
      Michael
      • jeff hammondJ Offline
        it used to work on mac… it quit working with lion and/or su8 and was never fixed in either of the two su8 maintenance releases..
        bummer because i liked/used/relied on that feature as well..
        πŸ‘Ž
          squiddenm
          Jeff thank you for answering my question!
          Let's hope it will be fixed in the next release.
          /michael
          • cheddaC Offline
            chedda
            Strange mine still works fine with su8 & lion.I am using the mighty (not magic) mouse perhaps that makes a difference ?
            Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
              divide still works.. it's just that the popup doesn't.
              for instance, say I have a 48" line then I right click -> divide.
              I used to be able to slide the mouse around and see a popup which would say something like '6 segments @8" ...5segments @ ~9 5/8"... 4segments @ 12"... etc..
              you're saying that still works for you?
                mwm5053
                I get the popup window on mine #segments, certain length.
                But a new issue as surfaced with DC components, changeable values are blacked out http://forums.sketchucation.com/viewtopic.php?f=11&t=45382 makes impossible to change cabinet size.
                2011 iMac
                SU 2015 Pro, 2017 Make
                V2 Twilight
                macOS Sierra 10.12.5
                  squiddenm
                  Strange things happened here.
                  Yesterday when i updated my iMac. Lion and SU 8. On this computer the popup surprisingly works. Actually I forgot to check if it worked before I updated, since I normally only work with graphics on my macbook.
                  I tried a reinstall of SU on my macbook without any result...
                  /michael
                  • cheddaC Offline
                    chedda
                    Yes i can confirm the little box with the number of divisions and lengths still appears. I am using a 5870 graphics card perhaps this is an open gl driver issue.
                      weird.. i found the culprit but i can't really figure out how this pref changed (or maybe it was just set this way upon my original su8 install ?? that's about the only thing i can think of… otherwise, i'm pretty sure the only way to change this would be to manually edit the .plist )
                      but all is working fine now.. just took me quite a few months to figure out 😞 πŸ˜•
                      • brookefoxB Offline
                        brookefox
                        Jeff (or anyone), what is the Windows equivalent of what your pic shows; is that a preferences screen? Sorry if it is; I'll check it.
                        ~ Brooke
                          i think the windows equivalent is the registry.. on mac, all preferences are stored in a .plist file..
                          and from what i gather, they're much less daunting/scary than visiting the registry πŸ˜‰
                          (but i could be wrong.. i don't even know what the registry is.. i just hear about it from time to time πŸ˜‰ )
                            It's a scary thing MS only invented to keep users at bay. πŸ˜•
                              squiddenm
                              Today I updated to 8.0.11751 - on my iMac, the popup stopped 😞 We must ask the Sketchup team about this small but but annoying issue.
                              /michael
