    Import osx SU Shortcuts to windows SU?
    6 Posts 3 Posters 536 Views 3 Watching
      Jeggebis
      Hi guys
      Running bootcamp for 3ds max, and sometimes i still need to use SU on the windows side. I would just really like to import all of my shortcuts i use in SU on the OSX side, but i can only import shortcuts on windows if its in a .dat format? I cant seem to export the shortcuts on OSX and the shortcut file itself is a .plist format?
      Any ideas? Google didn't help me πŸ˜•
        Jim
        Post the .plist file - maybe someone will write a converter.
          Jeggebis
          Well that would be great for future use! Now i just ended up manually setting up all the shortcuts. Tedious work, but needed to be done that way i guess πŸ˜„
          in zip format as i couldnt upload with a .plist extension
            Jim
            Parsing the .plist is not a problem, but I don't know to translate the Apple codes into the Windows equivalent. Particularly, what does the number 131072 mean?
            Apple Shortcuts File:
            	<string>Z</string>
            	<integer>131072</integer>
            	<string>viewZoomExtents;</string>
            	<string>e</string>
            	<integer>0</integer>
            	<string>selectEraseTool;</string>
            	<string>k</string>
            	<string>toggleDisplayBackEdges;</string>
            Windows Shortcuts File:
            0 0 0 H selectDollyTool;
            0 0 0 I selectImageIglooTool;
            0 0 0 O selectOrbitTool;
            0 0 0 A selectArcTool;
              This should do the conversion... The integers are mod-key codes.
              Read the file for usage...
              load"shortcutPlist2Dat.rb";TIG.shortcutPlist2Dat
                I've updated the script to include all mod-key combos...
                http://forums.sketchucation.com/viewtopic.php?p=407776#p407776
