Import osx SU Shortcuts to windows SU?
Hi guys
Running bootcamp for 3ds max, and sometimes i still need to use SU on the windows side. I would just really like to import all of my shortcuts i use in SU on the OSX side, but i can only import shortcuts on windows if its in a .dat format? I cant seem to export the shortcuts on OSX and the shortcut file itself is a .plist format?
Any ideas? Google didn't help me
Post the .plist file - maybe someone will write a converter.
Well that would be great for future use! Now i just ended up manually setting up all the shortcuts. Tedious work, but needed to be done that way i guess
Parsing the .plist is not a problem, but I don't know to translate the Apple codes into the Windows equivalent. Particularly, what does the number 131072 mean?
Apple Shortcuts File:
<string>Z</string> <integer>131072</integer> <string>viewZoomExtents;</string> <string>e</string> <integer>0</integer> <string>selectEraseTool;</string> <string>k</string> <integer>0</integer> <string>toggleDisplayBackEdges;</string>Windows Shortcuts File:
0 0 0 H selectDollyTool; 0 0 0 I selectImageIglooTool; 0 0 0 O selectOrbitTool; 0 0 0 A selectArcTool; -
This should do the conversion... The integers are mod-key codes.
Read the file for usage...
load"shortcutPlist2Dat.rb";TIG.shortcutPlist2Dat
I've updated the script to include all mod-key combos...
http://forums.sketchucation.com/viewtopic.php?p=407776#p407776
