    Make Group - context menu...
    6 Posts 5 Posters 357 Views 5 Watching
      minstrel
      Greetings,
      Wondering how to add a 'Make Group' option to the right click context menu?
      Using SketchUp Pro7.
      Thanks,
      minstrel
      • Alan FraserA Offline
        Alan Fraser
        It should already be there...right under Make Component. AFAIK it's always been there. The only time it doesn't show up is if you haven't selected enough geometry to make a valid group...like selecting a single edge or face (without its edges).
        3D Figures
          Note however that it does not appear if you click on a single entity though under the Edit menu, it is still available in such a case, too.
            minstrel
            Well, that nailed it!
            Thank you both for the quick solutions!
            minstrel
            • Jean LemireJ Offline
              Jean Lemire
              Hi folks.
              The choices to make a group or a component with a single entity are not available in the context menu.
              However, they are alwaysavailable in the Edit Menu.
              Just ideas.
                @jean lemire said:
                Hi folks.
                Just ideas.
                Therefore, select something and the use Window > Preferences > Shortcuts to make a shortcut key-combo to that very 'edit' command... and then you won't need a context-menu at all πŸ˜’
                So if G were 'Make Component' then Shift+G could be 'Make Group'...
                etc etc...
