    Glow effect
    renderpluginsextensions
    12 Posts 5 Posters 3.5k Views 5 Watching
    • N
      n3v
      Hi guys
      I've asked alot of questions recently so my apologies but heres another, does anyone know how to get that glow effect when the sun strikes a particular object? I suspect its post production but either way I'd like to know. this is someone elses but you can see how the white areas that catch the sun glow
      http://www.vismasters.com/VM_DisplayImage.cfm?SubmitID=671&nop=1&DispWidth=2540
      Thanks in advance
      • soloS
        solo
        Does V-ray have bloom options?
        http://www.solos-art.com
        • N
          n3v
          Not as far as I know??? but someone better qualified might be able to answer, I'm happy to do it as a post production effect but have no idea how to do it!
          • pbacotP
            This may not be exactly what you want, but along the same lines: http://forums.sketchucation.com/viewtopic.php?f=351&t=42258&start=0
            • N
              n3v
              Yeh not quite what I was after but worth saving for later,
              Thanks anyways!
              • dkendigD
                dkendig
                Lens Effects will be added in the next update. You can see the result in our latest update to V-Ray for Rhino: http://www.youtube.com/watch?v=Itk_EJSyJwc
                Devin Kendig
                Developer
                • N
                  n3v
                  thanks guys
                  it looks like 'bloom' is the right terminology for what I'm looking for, I've found this tutorial
                  to do it manually,
                  http://www.oferz.com/Tutorials/BloomEffect/BloomEffect.html
                  although it will affect the whole image, if I select the right vfb channels there is probably a way to isolate it to the areas I want.
                  • N
                    n3v
                    @n3v said:
                    thanks guys
                    to do it manually,
                    http://backgroundremovetutorials.wordpress.com/2011/06/07/creating-bloom-effect-in-photoshop/
                    • V
                      valerostudio
                      That's how most folks do it anyhow. Turning on such effects would increase render times and Photoshop is much more flexible.
                      • N
                        n3v
                        ah thanks man, I wasnt sure whether it was an in render feature or post production or even what it was called, now I know!
                        Still you have to be careful you dont get carried away with too much post production!
                        • V
                          valerostudio
                          There's a saying, "Photoshop is the best rendering engine on the market!"
                          • dkendigD
                            dkendig
                            I don't believe our lens effects hit the render time much or at all. You will definitely have to use Photoshop (or Gimp if you don't like spending money) in the meantime though.
                            Devin Kendig
                            Developer
