    Glow effect
    renderpluginsextensions
    12 Posts 5 Posters 3.5k Views 5 Watching
    • soloS
      Does V-ray have bloom options?
      • N
        n3v
        Not as far as I know??? but someone better qualified might be able to answer, I'm happy to do it as a post production effect but have no idea how to do it!
        • pbacotP
          This may not be exactly what you want, but along the same lines: http://forums.sketchucation.com/viewtopic.php?f=351&t=42258&start=0
          • N
            n3v
            Yeh not quite what I was after but worth saving for later,
            Thanks anyways!
            • dkendigD
              dkendig
              Lens Effects will be added in the next update. You can see the result in our latest update to V-Ray for Rhino: http://www.youtube.com/watch?v=Itk_EJSyJwc
              Devin Kendig
              Developer
              • N
                n3v
                thanks guys
                it looks like 'bloom' is the right terminology for what I'm looking for, I've found this tutorial
                to do it manually,
                404 Not Found
                (www.oferz.com)
                although it will affect the whole image, if I select the right vfb channels there is probably a way to isolate it to the areas I want.
                • N
                  n3v
                  @n3v said:
                  thanks guys
                  to do it manually,
                  http://backgroundremovetutorials.wordpress.com/2011/06/07/creating-bloom-effect-in-photoshop/
                  • V
                    valerostudio
                    That's how most folks do it anyhow. Turning on such effects would increase render times and Photoshop is much more flexible.
                    • N
                      n3v
                      ah thanks man, I wasnt sure whether it was an in render feature or post production or even what it was called, now I know!
                      Still you have to be careful you dont get carried away with too much post production!
                      • V
                        valerostudio
                        There's a saying, "Photoshop is the best rendering engine on the market!"
                        • dkendigD
                          dkendig
                          I don't believe our lens effects hit the render time much or at all. You will definitely have to use Photoshop (or Gimp if you don't like spending money) in the meantime though.
                          Devin Kendig
                          Developer
