    Subgroups To Layer
    10 Posts 5 Posters 583 Views 5 Watching
    • H Offline
      harnstein
      I leave all geometry on layer 0 and just put groups to layers (as i learned that last time)
      but i need to put subgroups of groups / components to a specific layer as well..
      Any advice?
      Maybe i'm just too blind to see πŸ˜‰
      still sketchin'
        Those are fine. As long as all your primitive geometry is on Layer0, put anything else where you wish.
        • H Offline
          harnstein
          I have lots of subgroups and subsubgroups in my groups which need to be on the same layer as the "top-group" layer.
          Any way to achieve that? It's a killing task to do it by hand with outliner..
          still sketchin'
          • H Offline
            harnstein
            No idea yet? πŸ˜„
            It would really be important for the export of my project.
            All objects are only imported onto a layer each object is placed on.
            Eg. a group with five subgroups is on layer 1. But each subgroup is still on layer 0. The imported result would be that all objects are on layer 0 still...
            Things like this always happen when it's getting time critical.. πŸ˜‰ i'd be really thankful for any tip.
            still sketchin'
            • gillesG Offline
              gilles
              Select group(s) component(s),open entity info and choose or create a layer.
              • H Offline
                harnstein
                Thanks gilles,
                i know,
                but there are too many groups within these groups to do it "by hand"..
                I did it for some groups with outliner but that's not really a solution.
                still sketchin'
                • gillesG Offline
                  gilles
                  This could be helpful:
                  http://forums.sketchucation.com/viewtopic.php?t=14975#p114380
                  The best way is to select the layer in entity info as you create the group but maybe it's to late.
                    Copy-paste this one-liner into the Ruby-Console +<enter>.
                    It changes nested groups' layer to be that of their container.
                    m=Sketchup.active_model;m.start_operation("S2L");m.definitions.to_a.reverse.each{|d|next unless d.group?;d.instances.each{|i|next if i.parent==m||!i.parent.group?;i.make_unique if d.instances[1];i.parent.instances[0].make_unique if i.parent.instances[1];i.layer=i.parent.instances[0].layer}};m.commit_operation
                    With deep nesting it might need running more than once. It's one step undo-able. If a group is inside a definition it can't take a layer as there might be several instances on different layers so how might we know ? However, if it's inside a group then it uses the layer of that group, after making it unique if necessary.
                      Why do you need the subgroups to be on a layer if their top group is on that layer. Turning off the visibility of the top group's layer will have the same impact whether the subgroups are on that layer or not.
                      • H Offline
                        harnstein
                        GREAT, thanks a lot TIG, i'll give it a try in a minute πŸ‘
                        It's about importing a skp-file to 3ds Max where 3ds splits up all groups with subgroups into seperate objects- and puts them to the layer each group was put on in SU. For toggeling visibility it would have been enough to change the layer of the top-group, you're right.
                        still sketchin'
