    How to Change Dimensions Using Scale?
    6 Posts 4 Posters 513 Views 4 Watching
    • BSquared18B
      BSquared18
      Suppose I have an object that measures 5 feet long by the tape measure, and I want to change the length to 3 feet 4 inches, retaining the proportions of the object.
      I could do that by trial and error using the Scale tool. I see that as you rescale an object, the box at the bottom of the screen shows the percentage difference as you drag the scale handle.
      To make the adjustment from 5 feet to 3 feet 4 inches in one scale movement, do I use a formula to figure out what the percentage change needs to be? If so, what is that formula? Or is there another, easier way to do it?
      Thanks,
      Bill
      • TIGT
        Select the object to be scaled...
        Use the Scale tool, start pulling in the direction desired and type 3'4" <enter>.
        The size is now 3'4" irrespective of what it was before.
        Scale will take dimensions if you append a units suffix [or in the case of feet+inches suffixes], otherwise it assumes a numerical factor.
        So 3', 45", 6.5m, 78cm and 9021mm will all work and set the selected size to be that dimension; whereas a plain 2 will scale x2 !
        Also note that the Tapemeasure tool can be used to Scale a whole group/component, or even the model, if you pick two points and then type in the required dimension, it asks you if you want to scale everything - Yes scales everything so that the picked distance is now what you've typed; this is in all axes.
        • BSquared18B
          BSquared18
          Great! Thanks.
          Bill
          • ipsketchpiI
            ipsketchpi
            Hi TIG
            Can you please explain little more these scale option with tape measure tool. I have tryed it but it does not work for me. Please post some picture example. These option could be very useful for me. Thank you in advance.
            /IP
            • GaieusG
              Here is what the Help Center is saying about the Tape measure when scaling a whole model and when scaling a given entity (group/component) only:
              http://support.google.com/sketchup/bin/answer.py?hl=en&answer=95006
              http://support.google.com/sketchup/bin/answer.py?hl=en&answer=116447
              • ipsketchpiI
                ipsketchpi
                thanks. I forgot about these nice SU online tutorial base. Will use it more in future
                /IP
