    How to Change Dimensions Using Scale?
    6 Posts 4 Posters 325 Views 4 Watching
    • BSquared18B Offline
      BSquared18
      Suppose I have an object that measures 5 feet long by the tape measure, and I want to change the length to 3 feet 4 inches, retaining the proportions of the object.
      I could do that by trial and error using the Scale tool. I see that as you rescale an object, the box at the bottom of the screen shows the percentage difference as you drag the scale handle.
      To make the adjustment from 5 feet to 3 feet 4 inches in one scale movement, do I use a formula to figure out what the percentage change needs to be? If so, what is that formula? Or is there another, easier way to do it?
      Thanks,
      Bill
        Select the object to be scaled...
        Use the Scale tool, start pulling in the direction desired and type 3'4" <enter>.
        The size is now 3'4" irrespective of what it was before.
        Scale will take dimensions if you append a units suffix [or in the case of feet+inches suffixes], otherwise it assumes a numerical factor.
        So 3', 45", 6.5m, 78cm and 9021mm will all work and set the selected size to be that dimension; whereas a plain 2 will scale x2 !
        Also note that the Tapemeasure tool can be used to Scale a whole group/component, or even the model, if you pick two points and then type in the required dimension, it asks you if you want to scale everything - Yes scales everything so that the picked distance is now what you've typed; this is in all axes.
          BSquared18
          Great! Thanks.
          Bill
          • ipsketchpiI Offline
            ipsketchpi
            Hi TIG
            Can you please explain little more these scale option with tape measure tool. I have tryed it but it does not work for me. Please post some picture example. These option could be very useful for me. Thank you in advance.
            /IP
              Here is what the Help Center is saying about the Tape measure when scaling a whole model and when scaling a given entity (group/component) only:
              http://support.google.com/sketchup/bin/answer.py?hl=en&answer=95006
              http://support.google.com/sketchup/bin/answer.py?hl=en&answer=116447
                ipsketchpi
                thanks. I forgot about these nice SU online tutorial base. Will use it more in future
                /IP
