    Help for new tool
    18 Posts 8 Posters 1.3k Views 8 Watching
      jorge2011
      I need a small plugin. There is something?
      an icon that when pressed (active camera in parallel mode) and when you press (active mode the camera perspective)
      anyone can help me? thank you very much.
        A shortcut key will toggle it on and off
          jorge2011
          yes, I know.
          but for me it is more practical to a toolbar. thank you very much for your reply
            Jim's Custom Toolbars plugin let you add a button for this: http://sketchuptips.blogspot.com/2008/06/custom-toolbars-release-08-06-01.html
              A shortcut is extremely easy to make - as it's a toggle, Shift+P or perhaps F9 etc would swap between the two view types...
              A button would be quite possible, but it'd be just an extra 'overhead' πŸ˜•
                @thomthom said:
                Jim's Custom Toolbars plugin let you add a button for this: http://sketchuptips.blogspot.com/2008/0 ... 06-01.html
                  JHArch
                  Any one know of why I can't Jim's custom toolbar plugin to work. I have tried downloading it numerous times. All of the other plugins that I have downloaded work fine. I am using SU 8 Pro. And have recently installed V-Ray. I don't know why but I am suspecting V-Ray might have something to do with the toolbar plugin not starting. Since Installing V-Ray it seems like it takes SU a full minute or more to open up when first starting. Previously SU opened almost instantly. I was hoping to create my own toolbars to save some real estate. I use shortcut keys for the majority of my commands, but still like a few handy icons on a toolbar. Any help or advice would be appreciated.
                  Thanks,
                    Describe what "doesn't work". It's impossible to guess what that might mean.
                    As for V-Ray, yes it makes SU slow to load. I disable VfSU and use my V-Ray Toys plugin to load it on demand: http://forums.sketchucation.com/viewtopic.php?t=15491
                      JHArch
                      I download the toolbar put the files: 'toolbars.rb' and the 'toolbars' folder in my SU plugins folder and upon opening SU nothing shows up. None of the menus,'plugins','View\toolbars' etc. show anything available from Jim's toolbar and none of the premade example toolbars show up in SU. From the SU operational side it is as if the new toolbar plugin doesn't even exist. Maybe it is just something simple that I am overlooking or doing wrong.
                        JHArch
                        Okay it was something simple. In case anyone else has a similar problem and comes across this post.
                        The tool bars had to be turned on. From the menus at the top of SU choose 'Window' 'Preferences' 'Extensions' then look for the 'Custom Toolbars' extension in the PlugIns list and put a check mark in the box. Close and restart SU.
                        • deaneauD Offline
                          deaneau
                          Hello @ All,
                          ok all post will be an older post..
                          my question is: can i custom the toolbar with plugins, too?
                          for example: i would use the Plugin Mover2 in a toobar:
                          could anybody guide me what i must write in the commands textfile?
                          Plugins>Toolbars>Files>Sketchup>commands
                          thank you for the help
                          Dean
                          MADE, BORN AND LIVING IN BERLIN
                          Big Thank You to all Programmers
                          Some German words are so long that they have a perspective. M.Twain
                          • gillesG Offline
                            gilles
                            Here is one I made (duplicate 😳 ) long time ago.
                            BarreOUTIL.zip
                            • deaneauD Offline
                              deaneau
                              hello, thank you for your files.. how and where i must save this in the plugin folder? is it a tool that interact with the toolbar plugin,too? is it an autonomouse plugin?
                              thank you dean
                                You need to find the ruby command to launch it by looking at the source code of the plugin. Find the menu/toolbar code of the plugin and see what methods they call.
                                  @deaneau said:
                                  eval % and than no clear code.. more scrambled
                                  Yes - they have deliberately scrambled the files to prevent reading the source. In which case you need to contact the author.
                                  @deaneau said:
                                  when i read between your lines, you mean, not all plugins support this function,right?
                                  It's not as if it's a feature. All plugins do need to call a method - and all plugins need to use the Ruby API to create menus. So all plugins will have some method being called from the menu or toolbar handler.
                                  However, there is no standard convention to how to write the source code. So you need to do some digging in order to understand the plugin you want to call. Remember that you are essentially hacking extra functionality so there will be no standard way for what you want to do.
                                  • deaneauD Offline
                                    deaneau
                                    hello tomtom thank you for your answer.
                                    im not ruby profi
                                    i see in your TT uv Toolkit items like
                                    #menu
                                    Context Menue
                                    #Toolbar
                                    any plugins are so different and so difficult to understand the code
                                    other plugins starts with
                                    i would love to configurate the toolbars like in Maxon Cinema4d πŸ˜‰
                                    its so easy and intuitive.
                                    thanks tom
                                    • deaneauD Offline
                                      deaneau
                                      ok i see, that an non-programer havnΒ΄t a chance to change anithing.
                                      do you have seen the youtube-video, to see how ease is it in cinema4d?
                                      tnx4 your answer dean
                                        Yea, I wish there was a UI manager. That SketchUp would allow users to create their own toolbars from all the available toolbars and menus. Maybe in the future - lets hope.
