    Alpha channel and SketchUp ground plane
    renderpluginsextensions
    3 Posts 3 Posters 1.4k Views 3 Watching
    • Z Offline
      Zejola
      How do you prevent Vray from rendering the default ground plane? I need an alpha channel of just the object I am trying to render (with no background or anything else visible) but I cannot find any settings to make this happen. Thanks for the help!
        Default ground plane? What are you referring to?
        Got a screenshot?
        • eidam655E Offline
          eidam655
          is Zejola referring to this effect? http://www.hdrmill.com/HDRI%20with%20Vray%20Tutorial/HDRI_MaxVray01.htm
          like when you get the v-ray infinite plane to receive the shadows, but the plane in itself is invisible and lets the background/HDR shine through?
          this tutorial doesn't work http://www.ehow.com/how_7369443_vray-sketchup-tutorial.html and that's a pity, i could use this effect πŸ˜•
          I'm using SketchUp 2017, V-Ray 3.4
