    Ruby to unhide hidden contents in selected group?
    4 Posts 3 Posters 973 Views 3 Watching
    • K Offline
      kaas
      Hello,
      I have lots of groups in my scenes and some of them have objects in them whose lines must be hidden. Now and then I have to edit the lines.
      Of course, I can: open the group -> unhide hidden geometry -> unhide all (in group) -> hide hidden geometry ....
      It would be very useful if I could just select the group and press a button to it all happen.
      Anyone know if there's a plugin that can unhide the contents of a selected group / component?
      Greetings, Max
        Since you can't edit those edges without opening the group for editing, why not just set up a keyboard shortcut that operates on the opened group?
          View > Hidden Geometry toggles on/off... so you can then see a hidden line and 'edit' it without having to un-hide it at all...
          This code will un-hide all edges in a group you are editing.
          It remembers the edges and when its inverse is run it hides them again.
          Copy+paste the code into a plain text file in the Plugins folder called "TIG-edgehidetoggle.rb". Restart Sketchup to get it to auto-load. To use it edit a group [double-click] and in the Ruby Console type TIG.edgehidetoggle to un-hide all edges, when you are done TIG.edgehidetoggle to hide all of those edges again, obviously erased or new edges are excluded from processing...
          You can easily make a menu item to shortcut to; or a toolbar button...
          require 'sketchup.rb'
          module TIG
            def TIG.edgehidetoggle()
              model=Sketchup.active_model
              ents=model.entities
              ants=model.active_entities
              return if ents==ants
              return unless ants.parent.group?
              unless @hiddenedges and @hiddenedges[0] ### show and remember
                @hiddenedges=[]
                ants.each{|e|@hiddenedges << e if e.class==Sketchup;;Edge and e.hidden?}
                @hiddenedges.each{|e|e.hidden=false} if @hiddenedges[0]
                return 'un-hidden'
              else ### hide and forget
                @hiddenedges.each{|e|e.hidden=true if e.valid?}
                @hiddenedges=[]
                return 'hidden'
          • K Offline
            kaas
            TIG - great! Exactly what I was looking for. Especially when working with large scenes my old workflow took some time. With your script, a menu-item & keyboard shortcut it's nice and easy.
            Thanks a lot
            Greetings, Max
