    Want white as material palette and info shows
    7 Posts 3 Posters 298 Views 3 Watching
    • brookefoxB Offline
      brookefox
      Uh, when is 'white' grey? All day around my desk, no matter the style. Please explain how to display and print white in the model as is shown in the materials palette and in entity info.
      ~ Brooke
        Aerilius
        That is shading. Window β†’ Shadows, check "use sun for shading" and set both sliders for Light and Dark to the maximum value.
        Another thing that ususally causes confusion (not an issue in this case) is the front/back color of the default material (Styles β†’ Edit β†’ Face Settings).
          brookefox
          Well, thank you, very much. You have lifted this fog from mine eyes.
          Setting those to the max, of course, screws up other things which were tweaked to work at the reduced settings.
          Another way: uncheck use sun for shading, in which case values may be left alone?
          ~ Brooke
            Have you played with crossing the shadow sliders? Set the light slider all the way to the left and the dark slider all the way to the right.
              brookefox
              Thanks, Dave, but for me that is the same as unchecking 'use the sun'.
              ~ Brooke
                Strange. I get two different results.
                  brookefox
                  Your results are surely more typically accurate but my use at the moment is for a flat 2D sheet view.
                  I will try to remember your idea. I will, but I bet I don't.
                  ~ Brooke
