    Gutter builder?
    8 Posts 4 Posters 2.2k Views 4 Watching
      Ands43
      Is there a plugin for rain water gutters? thanks
      • TIGT Online
        What's up with the native 'FollowMe' ?
          Ands43
          Gutters are quite fiddly with all the fastening brackets etc, plus I often have to draw different size buildings and 😎
            Maybe ProfilBuilder can help for some forms
            or 3skeng
              Ands43
              3skeng is windows only, I'll have a look at profile builder.
              How are ruby plugins made do you need to be a genius or is it for mere mortals as well?
              • W Offline
                Whaat
                Profile Builder will save you lots of time.
                There is a free evaluation version available here:
                http://www.smustard.com/script/ProfileBuilderFree
                • TIGT Online
                  Why do you want to model in such detail?
                  Do you put screws into door-hinges ?
                  Do you realize how complex a Plugin would have to be to do everything you'd want [as oppose to need] to make detailed guttering ?
                  Tools like ProfileBuilder [now in a free-version too] can help you, but you'll still need to draw a profile and a path, unless you are happy to accept a premade one... It won't do brackets, joints, spigots etc...
                  Here's the native manual way...
                  Draw a few common cross-sections of gutter and save them as components, you can then use these in future SKPs as needed, exploding them to an oriented face for a FollowMe around a path.
                  Make a few [simple] brackets as components too, place instances of these on the gutters and use Move+Ctrl+Nx to array copies along gutter lengths at desired centers etc.
                  This is not a difficult thing to do by hand, but all of the convoluted coding required and the permutations needed to do it 'automatically' in a script would require so many inputs from you it'll be quicker done manually... πŸ˜’
                    Ands43
                    Thanks Tig πŸ˜’ πŸ˜‰
