    Please help with FILLET Plugin
    11 Posts 4 Posters 1.2k Views 4 Watching
    • dereiD Offline
      derei
      I have this 2D Fillet plugin that you can find here http://www.ohyeahcad.com/download/ (the first one). But I can't control the number of segments of corner arc.
      I am asking for help with this. I would like a simple way to change the number of the segments. Let's say, if I add the letter S after the number inserted in VCB, to be interpreted as number of segments, then to imput the normal radius.
      Is it hard? Can it be done? Are you willing to help me with this?
      Thank you very much.
      DESIGNER AND ARTIST DEREI.UK
      • TIGT Online
        My 2dTools includes a Fillet tool - this works on any two intersecting pair of edges you click on - even in '3d'.
        You can type 12s to set the number of segments to '12' [min. is 3] and also any radius you want - e.g. 100, before picking the second edge. These values are remembered during that session of the SKP.
        Typing the radius as 0 makes it into a trim/extend tool [that is the session's starting default].
        It also places a cpoint [guide] at each fillet's arc-center.
        It is also 'toggle-able' into a 'chamfer tool' - where you can then enter one dimension for the offset on both edges, e.g. 100; OR two dimensions separated by a ':' for uneven chamfers for edge 1 and 2 - e.g. 100:200...
        • dereiD Offline
          derei
          I need a tool that can accept two segments also, as I use (for small radii) only two segments. It's enough for most cases, as after I smooth it, it's just what I need.
          • massimoM Offline
            massimo Moderator
            Fredo's bezier spline plugin has something like that: draw lets say a rectangle-->select it-->rigth click-->BZ-convert to-->polyline arc corners-->input the offset-->then input the precision in the VCB (number of segments). You also have a polyline chamfer type.
            • TIGT Online
              Three segments is the minimum for an arc, in the native arc tool too.
              • massimoM Offline
                massimo Moderator
                Well if you need something like the picture below, just type 8s since your arc is 1/4 of a circle in this case.
                • dereiD Offline
                  derei
                  Please, allow me to disagree... native arc tool allows to draw arc from only two segments.
                  Here is the proof.
                    • TIGT Online
                      I am mistaken.
                      Three it is not.
                      The 2dFillet tool is easily adjusted from min. 3 to 2... I'll make the change... πŸ˜’
                      I was thinking of the native 'circle' which obviously has to have three...
                      • dereiD Offline
                        derei
                        @tig said:
                        I am mistaken.
                        Three it is not.
                        Thank you very much, TIG
                        • TIGT Online
                          Here's v5.2 of my 2dToolset, containing the updated 2dFillet - arc segments >=2 <=999 - It could go higher [9999] BUT that is crazy bad!]
                          http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
