    Please help with FILLET Plugin
    11 Posts 4 Posters 1.4k Views 4 Watching
      My 2dTools includes a Fillet tool - this works on any two intersecting pair of edges you click on - even in '3d'.
      You can type 12s to set the number of segments to '12' [min. is 3] and also any radius you want - e.g. 100, before picking the second edge. These values are remembered during that session of the SKP.
      Typing the radius as 0 makes it into a trim/extend tool [that is the session's starting default].
      It also places a cpoint [guide] at each fillet's arc-center.
      It is also 'toggle-able' into a 'chamfer tool' - where you can then enter one dimension for the offset on both edges, e.g. 100; OR two dimensions separated by a ':' for uneven chamfers for edge 1 and 2 - e.g. 100:200...
      • dereiD
        derei
        I need a tool that can accept two segments also, as I use (for small radii) only two segments. It's enough for most cases, as after I smooth it, it's just what I need.
        DESIGNER AND ARTIST DEREI.UK
        • massimoM
          massimo Moderator
          Fredo's bezier spline plugin has something like that: draw lets say a rectangle-->select it-->rigth click-->BZ-convert to-->polyline arc corners-->input the offset-->then input the precision in the VCB (number of segments). You also have a polyline chamfer type.
            Three segments is the minimum for an arc, in the native arc tool too.
            • massimoM
              massimo Moderator
              Well if you need something like the picture below, just type 8s since your arc is 1/4 of a circle in this case.
              • dereiD
                derei
                Please, allow me to disagree... native arc tool allows to draw arc from only two segments.
                Here is the proof.
                    I am mistaken.
                    Three it is not.
                    The 2dFillet tool is easily adjusted from min. 3 to 2... I'll make the change... πŸ˜’
                    I was thinking of the native 'circle' which obviously has to have three...
                    • dereiD
                      derei
                      @tig said:
                      I am mistaken.
                      Three it is not.
                      Thank you very much, TIG
                        Here's v5.2 of my 2dToolset, containing the updated 2dFillet - arc segments >=2 <=999 - It could go higher [9999] BUT that is crazy bad!]
                        http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
