    [Plugin] Multiple Offsets (Updated 09-Feb-2014)
    37 Posts 16 Posters 78.7k Views 16 Watching
    • sdmitchS
      sdmitch
      In response to http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=43426
      One last update. Addressed problem of possible conflict with other plugins
      and fixed a bug when using a delta values list with multiple faces.
      Select one or more faces. Run the plugin and select one of three offset methods.
      Constant: Input number of offsets, distance between offsets, direction to
      offset, either inside, outside, or both, and whether the selected face(s) and all
      created faces are to be deleted, select No to keep faces.
      Formula: Enter number of offsets, distance to first offset, direction to offset,
      delete faces Yes or No, select operator + or *, and value to add or multiply by.
      List: Select direction of offsets, delete faces Yes or No, a list of offsets
      separated by commas, choose type of offset either absolute or a delta value
      to be added to the last offset value. If the offsets are a repeated sequence,
      end the list with *X, where X = the number of repetitions for the offset
      sequence entered.
      In one test case, the offsets were placed opposite of the direction setting. Why this occurred is still a mystery. The simple solution is to undo, rerun and choose the opposite direction.
      The latest version is available from the PluginStore...http://sketchucation.com/pluginstore?pln=Multiple_Offsets
      http://sdmitch.blogspot.com/
        Maybe it will cool also to keep the surfaces ? (first and news)
        Because we can't make surface with the new curves even welded! โ“
        Here with the plug "create face"
        • sdmitchS
          sdmitch
          Retracing any segment of the closed curve with the Line Tool should create a face.
            Redraw a "big" above the result and intersect all make the trick and very more speedy than all redraw with the ๐Ÿ˜‰
            • sdmitchS
              sdmitch
              New version has been posted
                You definitly rocks!!! ๐Ÿ‘ ๐Ÿ˜Ž โ˜€
                • D
                  dtrarch
                  Sam
                  Good stuff and thank you. ๐Ÿ‘
                  dtr
                  • B
                    Ben Ritter
                    sdmitch, Thank you!
                    • sdmitchS
                      sdmitch
                      Major update posted today. Offsets can be created by three methods
                      seperated by commas, choose type of offset either absolute or a delta value
                      end the list with *X, where X = the number of repititions for the offset
                      sequence entered.
                      • simon le bonS
                        simon le bon
                        Thank you Sam,
                        It's a gem. ๐Ÿ‘
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Boutons/Ruby.png
                        older version overwritten by the new one ๐Ÿ˜‰
                        ++simon
                        • simon le bonS
                          simon le bon
                          Hi Pilou and Sam,
                          Multiple Offsets works for me with Su7
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/MultipleOffsets001.jpg
                          However problems with the List Options:
                          • List:Offset by * 3
                            Absolute and Delta choice gives the same result:
                          x3 Delta offset (see pict)
                          (colored after for a better watch)
                          • List: Offsets: + operator don't work and deletes the offseted faces
                          simon
                            curious nothing append on V7 and V6! ๐Ÿ˜ฎ
                            All menu appear but nothing is done! Does this normal ?
                            Work like a charm in V8 ! ๐Ÿ˜Ž (aespecially the * x with a list ! ๐Ÿ‘ ๐Ÿ˜‰
                            As the "exotic Push Pull" seems have a problem maybe will be a good thing to input it inside this plug during the calculate ?
                            Or See my new request ๐Ÿ˜‰
                              @Simon
                              Curious you write 20,30,40,50*3, that must be 20,30,40,50,*3 ๐Ÿ˜‰
                              Edit : in fact that gives the same result! ๐Ÿ’š
                              • guanjinG
                                guanjin
                                sequence entered.
                                Great tool invention
                                Can realize line migration, generating surface?
                                Perhaps we should not be too many requests
                                thank you sdmitch
                                I come from China, is to learn
                                • guanjinG
                                  guanjin
                                  sequence entered.
                                  DWG files import, Is no surface of
                                  thank you sdmitch
                                  • guanjinG
                                    guanjin
                                    sequence entered.
                                    DWG files import, Is no surface of ,
                                    thank you sdmitch
                                      I have added some plugins for another things in V8
                                      All menus Offset Multiples are fine but nothing append! ๐Ÿ˜ฒ
                                      Seems there is a conflict with another plugs! ๐Ÿ˜ฎ
                                      Must find the the culprit(s)! (resolved see the next page for see the culprit) ๐Ÿ˜‰
                                      • B
                                        blajnov
                                        Respected sdmitch, the new version of a plug-in, doesn't work in SketchUp 8 Pro M2...๐Ÿ˜ข
                                        The previous works perfectly well.
                                        • guanjinG
                                          guanjin
                                          I also SU8M2, no problem
                                          • sdmitchS
                                            sdmitch
                                            blajov, sorry about that but I only have SU8 Free at my disposal so there is no way for me to determine why that is the case.
                                            • 1 / 2
