    [Plugin] Generate Ceiling Grid (Updated 27-Mar-2014)
    99 Posts 23 Posters 99.4k Views 23 Watching
    • sdmitchS Offline
      sdmitch
      Apparently all my test shapes have been at Z=0. Elevation does matter. Sorry about that.
      Well at least I thought elevation mattered. I did a move/copy on a shape and elevated it. When I ran the plugin, I got the pulled down faces without texture, but when I created a elevated shape, it didn't have the problem. I then tried to duplicate the create at Z=0 and move/copy to an elevation and results were normal! What a lovely thing an intermittent problem is!!!
      http://sdmitch.blogspot.com/
      • Z Offline
        ZFRPS
        first,I need to speak sorry,and i get carried away for this plugin,because i believe this plugin is one of "BIM" plugins,BIM need details ,if this can done , I hope !
        However,i must thanks sdmitch and everyone again,this plugin is great.
        sketchup is bim
        • gullfoG Offline
          gullfo
          yea, being its occurring over several runs, it may be a variable scope issue where something is persisting which causes the subsequent run to make incorrect assumptions...
          Glenn
          http://www.runnel.com
            Ben Ritter
            Sam, thank you. Good stuff!
              SUFractal
              Sam, I had tried both methods you described, but still had the same issues.
              • sdmitchS Offline
                sdmitch
                Ok, I have done about all I can do with this plugin. I have tested numerous shapes including gullfo's and the plugin produced the expected results, with minor exceptions, without fail using all size,origin,rotation options while creating tiles.
                zfrps, I fixed that "gap" thing for you.
                  SUFractal
                  Working OK from what I can see. Thanks so much sdmitch!
                  • guanjinG Offline
                    guanjin
                    Create a surface option is not valid, how the choices that are surface
                    Choose, or have surface
                    I come from China, is to learn
                      tomot
                      You do have a surface now, you can place a texture on the entire surface, unfortunately I would have preferred to see the use of individual tiles as we had previously. I inadvertently over wrote and did not save the last script. Perhaps if sdsmith is not getting tired of this yet πŸ˜„ he could introduce 3 choices: none, tiles, surface.
                      my plugins
                      tomot
                      • sdmitchS Offline
                        sdmitch
                        You get the "surface" if you say "No" to Make Tiles. If you don't want the surface, simply delete it.
                        • guanjinG Offline
                          guanjin
                          We asking for too much, thank you for the great plug πŸ˜‰
                          • RonSR Offline
                            RonS
                            Works like a charm for me. Thank You Sam for all of your hard work.
                            Design is not just what it looks like and feels like. Design is how it works.
                            Steve Jobs
                            RonS
                            • guanjinG Offline
                              guanjin
                              No matter how select all the options are in the middle, invalid!!! πŸ˜’
                                tomot
                                I was mistakenly concerned that I would not be able to remove individual panels in order to create light panels. But that is not the case, the Surface can be intersected with the model (namely the Grid), by right-clicking the context menu. Now that the Surface and the Grid have been intersected, individual panels can be be removed as required, for lights. thanks again sdmith
                                my plugins
                                tomot
                                • sdmitchS Offline
                                  sdmitch
                                  The "Origin Pt:" selection controls the position. If "Corner" gives you the same
                                  results as "Center" then you appear to be the only one.
                                  • guanjinG Offline
                                    guanjin
                                    The same surface option, is invalid, only the first option is effective!
                                    πŸ˜’
                                    • sdmitchS Offline
                                      sdmitch
                                      πŸ˜’
                                      If Make Tiles = Yes, you get a group of tiles, one for each "cell", which are painted with the current material. If Make Tiles = No, the original selected shape is painted with the current material . If you don't want a ceiling, simply delete the "Ceiling" group.
                                      If you seperate the Ceiling from the Grid, you will see this difference more clearly.
                                        SUFractal
                                        Thanks for all the hard work and updates sdmitch!
                                        • guanjinG Offline
                                          guanjin
                                          Thank you for your help, I understand, hard![/quote]
                                          • guanjinG Offline
                                            guanjin
                                            • 4 / 5
