    [Plugin] Generate Ceiling Grid (Updated 27-Mar-2014)
    99 Posts 23 Posters 101.5k Views 23 Watching
      tomot
      @guanjin said:
      Create a surface option is not valid, how the choices that are surface
      Choose, or have surface
      You do have a surface now, you can place a texture on the entire surface, unfortunately I would have preferred to see the use of individual tiles as we had previously. I inadvertently over wrote and did not save the last script. Perhaps if sdsmith is not getting tired of this yet πŸ˜„ he could introduce 3 choices: none, tiles, surface.
      my plugins
      tomot
      • sdmitchS Offline
        sdmitch
        You get the "surface" if you say "No" to Make Tiles. If you don't want the surface, simply delete it.
        http://sdmitch.blogspot.com/
        • guanjinG Offline
          guanjin
          We asking for too much, thank you for the great plug πŸ˜‰
          • RonSR Offline
            RonS
            Works like a charm for me. Thank You Sam for all of your hard work.
            Design is not just what it looks like and feels like. Design is how it works.
            Steve Jobs
            RonS
            • guanjinG Offline
              guanjin
              No matter how select all the options are in the middle, invalid!!! πŸ˜’
                tomot
                I was mistakenly concerned that I would not be able to remove individual panels in order to create light panels. But that is not the case, the Surface can be intersected with the model (namely the Grid), by right-clicking the context menu. Now that the Surface and the Grid have been intersected, individual panels can be be removed as required, for lights. thanks again sdmith
                my plugins
                tomot
                • sdmitchS Offline
                  sdmitch
                  The "Origin Pt:" selection controls the position. If "Corner" gives you the same
                  results as "Center" then you appear to be the only one.
                  • guanjinG Offline
                    guanjin
                    The same surface option, is invalid, only the first option is effective!
                    πŸ˜’
                    • sdmitchS Offline
                      sdmitch
                      πŸ˜’
                      If Make Tiles = Yes, you get a group of tiles, one for each "cell", which are painted with the current material. If Make Tiles = No, the original selected shape is painted with the current material . If you don't want a ceiling, simply delete the "Ceiling" group.
                      If you seperate the Ceiling from the Grid, you will see this difference more clearly.
                        SUFractal
                        Thanks for all the hard work and updates sdmitch!
                        • guanjinG Offline
                          guanjin
                          Thank you for your help, I understand, hard![/quote]
                          • guanjinG Offline
                            guanjin
                            • Z Offline
                              ZFRPS
                              Dear sdmitch,you are Generous man,i love you!
                              same Building structure tool is BIM tool of structure,your plugin is BIM tool of decoration project.
                              I along believe sketchup is BIM that best !
                              If have someone interesting for BIM-sketchup,I would like to go for together!
                              sketchup is bim
                              • guanjinG Offline
                                guanjin
                                πŸ‘ πŸ‘
                                • guanjinG Offline
                                  guanjin
                                    tspco
                                    I just downloaded the latest version, great job SD!. I am running on my standby computer because my main machine died, with luck this will be corrected with a new power supply I will get later today.
                                    The backup machine is a pieced together XP machine, with a 2 gig single core processor, so it takes a while for the plugin to complete it's task, only a few seconds though.
                                    I tried the plugin with the tiles "turned on", I wanted to see how hard it would be to remove a tile for the purposes of replacing it with a light fixture, I edited the tile group, and triple clicked the tile I wanted to remove, worked great!
                                    Thanks so much for a great plugin!
                                    SU make 2017, /Twilight Render Hobby
                                    Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                                      jpalm32
                                      Thanks! Laying out a tin ceilling, works great. πŸ‘
                                      24x24 drop-in tins
                                        pankaj_tamore
                                        Good job. buddy keep it! your plugin works really well with curvy periphrey ceiling too!
                                        • ElibjrE Offline
                                          Elibjr
                                          Wow! Thank you! This is one of the best single architectural plugins I've seen. It works wonderfully! It does exactly what you expect it to do. Great job Sdmitch! This is a real time saver!
                                          • alexchrA Offline
                                            alexchr
                                            πŸ‘ πŸ‘ πŸ‘
                                            merci, c'est super!
                                            • 4 / 5
