    [Plugin] Generate Ceiling Grid (Updated 27-Mar-2014)
    99 Posts 23 Posters 107.2k Views 23 Watching
    • guanjinG
      guanjin
      @sdmitch said:
      Ok, I have done about all I can do with this plugin. I have tested numerous shapes including gullfo's and the plugin produced the expected results, with minor exceptions, without fail using all size,origin,rotation options while creating tiles.
      zfrps, I fixed that "gap" thing for you.
      Create a surface option is not valid, how the choices that are surface
      Choose, or have surface
      • T
        tomot
        You do have a surface now, you can place a texture on the entire surface, unfortunately I would have preferred to see the use of individual tiles as we had previously. I inadvertently over wrote and did not save the last script. Perhaps if sdsmith is not getting tired of this yet πŸ˜„ he could introduce 3 choices: none, tiles, surface.
        my plugins
        tomot
        • sdmitchS
          sdmitch
          You get the "surface" if you say "No" to Make Tiles. If you don't want the surface, simply delete it.
          http://sdmitch.blogspot.com/
          • guanjinG
            guanjin
            We asking for too much, thank you for the great plug πŸ˜‰
            • RonSR
              RonS
              Works like a charm for me. Thank You Sam for all of your hard work.
              Design is not just what it looks like and feels like. Design is how it works.
              Steve Jobs
              RonS
              • guanjinG
                guanjin
                No matter how select all the options are in the middle, invalid!!! πŸ˜’
                • T
                  tomot
                  I was mistakenly concerned that I would not be able to remove individual panels in order to create light panels. But that is not the case, the Surface can be intersected with the model (namely the Grid), by right-clicking the context menu. Now that the Surface and the Grid have been intersected, individual panels can be be removed as required, for lights. thanks again sdmith
                  my plugins
                  tomot
                  • sdmitchS
                    sdmitch
                    The "Origin Pt:" selection controls the position. If "Corner" gives you the same
                    results as "Center" then you appear to be the only one.
                    • guanjinG
                      guanjin
                      The same surface option, is invalid, only the first option is effective!
                      πŸ˜’
                      • sdmitchS
                        sdmitch
                        πŸ˜’
                        If Make Tiles = Yes, you get a group of tiles, one for each "cell", which are painted with the current material. If Make Tiles = No, the original selected shape is painted with the current material . If you don't want a ceiling, simply delete the "Ceiling" group.
                        If you seperate the Ceiling from the Grid, you will see this difference more clearly.
                          SUFractal
                          Thanks for all the hard work and updates sdmitch!
                          • guanjinG
                            guanjin
                            Thank you for your help, I understand, hard![/quote]
                            • guanjinG
                              guanjin
                              • Z
                                ZFRPS
                                Dear sdmitch,you are Generous man,i love you!
                                same Building structure tool is BIM tool of structure,your plugin is BIM tool of decoration project.
                                I along believe sketchup is BIM that best !
                                If have someone interesting for BIM-sketchup,I would like to go for together!
                                sketchup is bim
                                • guanjinG
                                  guanjin
                                  πŸ‘ πŸ‘
                                  • guanjinG
                                    guanjin
                                    • T
                                      tspco
                                      I just downloaded the latest version, great job SD!. I am running on my standby computer because my main machine died, with luck this will be corrected with a new power supply I will get later today.
                                      The backup machine is a pieced together XP machine, with a 2 gig single core processor, so it takes a while for the plugin to complete it's task, only a few seconds though.
                                      I tried the plugin with the tiles "turned on", I wanted to see how hard it would be to remove a tile for the purposes of replacing it with a light fixture, I edited the tile group, and triple clicked the tile I wanted to remove, worked great!
                                      Thanks so much for a great plugin!
                                      SU make 2017, /Twilight Render Hobby
                                      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                                        jpalm32
                                        Thanks! Laying out a tin ceilling, works great. πŸ‘
                                        24x24 drop-in tins
                                        • P
                                          pankaj_tamore
                                          Good job. buddy keep it! your plugin works really well with curvy periphrey ceiling too!
                                          • ElibjrE
                                            Elibjr
                                            Wow! Thank you! This is one of the best single architectural plugins I've seen. It works wonderfully! It does exactly what you expect it to do. Great job Sdmitch! This is a real time saver!
                                            • 4 / 5
