    Change color of Protractor and Rotate tool
    3 Posts 3 Posters 338 Views 3 Watching
    • J
      jgt1942
      Is there a way to changed the green color of the Protractor and Rotate tool to a darker color? For me the bright green is almost impossible to see. I'd like to change it to a dark green.
      jgt
      • TIGT
        There's nothing available.
        However, you can make a Style that has the best contrast between background/ground/sky/default-materials etc... to suit you.
        Also you can adjust the contrast/brightness/gamma of your computer's display to optimize what you see...
          Are you using the default blue-gray background color? I find that the green protractors and lines are particularly difficult to see against it. I have my background set to white and that works for me.
