    Altared Images
    36 Posts 15 Posters 6.2k Views 15 Watching
      mac1
      well head or blowout preventer
      • FletchF Offline
        Fletch
        @paul russam said:
        Here's a link to a very rough YouTube vid showing the Pixeet app on my iPad:
        very very 😎 ❗
        Fletch
        3D Modeling addict. Former owner/developer of Twilight Render. sleepinggiantvisual.com
        • Paul RussamP Offline
          Paul Russam
          @roger
          Only in a darkened room
          @Fletch
          You try holding an iPhone next your your ear with an iPad at arms length and spinning on the spot. If it wasn't for the fact that I'd sensibly had my 11am whisky it'd been a lot worse. πŸ˜‰
          @mac1
          Nope
          I'll give you a clue, Inside the VAB an S-IC, S-IIB, S-IVB, LM,SM and CM are stacked on an MLP/LUT and then taken using the CT to either LC39A or LC39B whereupon the CT parks the MLP/LUT upon 6 of the things above
          Come on I'm practically drawing you a picture πŸ˜‰
          Paul Russam
          English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
          • Bob JamesB Offline
            Bob James
            Tiedowns for the Mobile Launch Platform
            VAB - Vehicle Assembly Building
            S-IC, S-IIB, S-IVB, LM,SM and CM - Vehicle stages
            MLP/LUT - Mobile Launch Platform/Umbilical Tower
            CT - Crawler Tractor
            LC39A or LC39B - Launch Pads
            • hellnbakH Offline
              hellnbak
              How many whiskies did you say you had? 😲
                Paul Russam
                Mr James is quite right.
                I got the as built drawings for the Mobile launch platform/Launch umbilical tower for the SaturnV, the scale of it is just fantastic. 78 pages of what you see below!
                I've seen a few models but I fancied doing my own, There are lots of photos of the Saturn V but finding good reference photos of the launch platform is hard work.
                Paul Russam
                • hellnbakH Offline
                  hellnbak
                  You'd think that with something this massive they could have sprung for something a little beefier than those '49 Buick shock absorbers πŸ˜†
                    Paul Russam
                    If I've understood it right, they're adjusters. the top and bottom connectors are threaded into the centre section and it's 8 sided like a big nut. Turning it with what must be the mother of all spanners would enable them to adjust the tie down's angle. That part of the drawing was hard to read.
                    There are 2 ball joints (one at the top, one at the bottom) within the tie down post. I asume they'd have to adjust the tie downs position due to thermal expansion etc on the Launch platform.
                    Paul Russam
                    • leedeeteeL Offline
                      leedeetee
                      This project is staggering. Wow. I have thoroughly enjoyed seeing all your fabulous WIP shots. Thanks for posting.
                      • urgenU Offline
                        urgen
                        @paul russam said:
                        Last nights render.....
                        ...O-O-o! 😲
                        ...Great,really Great!Thanks Paul! πŸ‘
                        --pupil forever...------
                          Paul Russam
                          Here's this weekend's panorama. 64 hours on a Core2 Quad 2.5Ghz 4000x2000 jpeg
                          https://lh4.googleusercontent.com/-Uamkg-K_r_c/T0IFHRJc37I/AAAAAAAAGHQ/QikYoZSLK5I/s800/Test23-Easy09-Exp18.jpg
                          Links to full size 4000x2000 jpeg
                          Link to panorama on Pixeet
                          Paul Russam
                            leedeetee
                            Could I ask what the stats for this model? (Apologies if I've missed it elsewhere).
                            Faces/mb etc?
                              Paul Russam
                              Edges : 4,573,393
                              Faces : 2,120,510
                              Components : 35,953
                              Groups : 6,100
                              Comp Definitions : 958
                              Layers : 63
                              Material : 256
                              Zipped : 41.5 Mb
                              Paul Russam
                              • jo-keJ Offline
                                jo-ke
                                really great stuff. Nice idea with the panoramas. Very inspiring!
                                I have some problems with twilightrender with huge models and big imagesizes. Mostly twilightrender gets stuck.
                                http://www.zz7.de
                                  Paul Russam
                                  I'm using XP and this model wouldn't render, it would get through the processing stage and then go straight to Complete without rendering anything. I then found this thread on the Twilight forum and it enabled me to have enough free memory to render it.
                                  Additionally I used ThomThom's CleanUp plugin a extensively to purge a lot of waisted faces/edges etc. At one point I copied the model several times and in each one cleared out everything except floors or walls or windows etc. I then cleaned that particular model of everything (layers/styles/scenes/edges/faces etc etc)and then reimported it into a clean SketchUp file. This got rid of a lot of stuff I didn't even know was in there.
                                  I thought I'd been efficient in my modeling but CleanUp showed just how wrong I was. 😳
                                  Paul Russam
                                    Paul Russam
                                    Tonight's Render
                                    3000x2250 Image looking from altar towards front doors with depth of field effect to focus eye on roundal in front of altar (I hope πŸ˜„ )
                                    Click to View Progress - Updated every 10mins
                                    Edit:
                                    Instead of creating a new post, I'll just edit this one.
                                    Here's the finished render and the pure SU view:
                                    https://lh5.googleusercontent.com/-nA0Oup8RJ4Y/T0Nb9g7fdEI/AAAAAAAAGHY/0y-yEFEp2Fg/s700/Test24-Easy09-F14-Exp20.jpg
                                    https://lh3.googleusercontent.com/-A2n560wyWVA/T0NcGf9qtNI/AAAAAAAAGHc/NtlFCJ7LifE/s700/Test24-SU.jpg
                                    Something is not quite right with the rendering, if your look at the roundal on the floor you can see 1/4 of it look different, I've make it in 4 quarters so I could get 4x1200pix images for the texture(s).
                                    In every other view its fine, I changed nothing and all the settings match in the 4 materials so I'm not sure what's going on.
                                    Paul Russam
                                    • 2 / 2
