    Altared Images
    36 Posts 15 Posters 7.0k Views 15 Watching
    • Mike LuceyM
      Mike Lucey
      Great stuff Paul. I have earmarked this topic and will view over the weekend. Its great to see 'real world' projects ๐Ÿ‘
      • boofredlayB
        boofredlay
        Glad to see more of your work again Paul. Great stuff indeed.
        • Paul RussamP
          Paul Russam
          It may seem like I've only ever worked on this project bit its not true, ITS NOT TRUE I TELL YOU!!! ๐Ÿ˜„
          They've either been for too boring or in the case of the prison far to sensitive to show.
          This is a little something I'm having fun with for my own self gratification, can you guess what it is?
          Paul Russam
          English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
          • hellnbakH
            hellnbak
            It's a paperweight (for very large papers)
            • Paul RussamP
              Paul Russam
              Close, its definitely for holding something down
              Paul Russam
              • daleD
                dale
                Paul
                So glad to see you back. The Church imagery is beyond stunning.
                As for your personal project, it looks to me like it is a mounting platform for The Antikythera mechanism, or a really large septic field "D" box. ๐Ÿ˜„
                Welcome back.
                  Roger
                  You said it yourself. It is a self-gratification machine. ๐Ÿ˜ฎ
                  http://www.azcreative.com
                  • hellnbakH
                    hellnbak
                    ๐Ÿคฃ
                    • Paul RussamP
                      Paul Russam
                      I've just kicked off this weekends panorama, I've set Twilight to save it every 10mins to my dropbox folder.
                      Here's a link to it:
                      4000x2000 jpeg panorama
                      Twilight tends to create big jpegs (opening and resaving them usually halves their size) so be warned if you chose to view it. It could be 10Mb or more hence why I've done a URL link and not an IMG link here.
                      As I said it'll be updated every 10mins so it'll get more refined as time goes on.
                      Paul Russam
                        mac1
                        well head or blowout preventer
                        • FletchF
                          Fletch
                          @paul russam said:
                          Here's a link to a very rough YouTube vid showing the Pixeet app on my iPad:
                          very very ๐Ÿ˜Ž โ—
                          Fletch
                          • Paul RussamP
                            Paul Russam
                            @roger
                            Only in a darkened room
                            @Fletch
                            You try holding an iPhone next your your ear with an iPad at arms length and spinning on the spot. If it wasn't for the fact that I'd sensibly had my 11am whisky it'd been a lot worse. ๐Ÿ˜‰
                            @mac1
                            Nope
                            I'll give you a clue, Inside the VAB an S-IC, S-IIB, S-IVB, LM,SM and CM are stacked on an MLP/LUT and then taken using the CT to either LC39A or LC39B whereupon the CT parks the MLP/LUT upon 6 of the things above
                            Come on I'm practically drawing you a picture ๐Ÿ˜‰
                            Paul Russam
                            • Bob JamesB
                              Bob James
                              Tiedowns for the Mobile Launch Platform
                              VAB - Vehicle Assembly Building
                              S-IC, S-IIB, S-IVB, LM,SM and CM - Vehicle stages
                              MLP/LUT - Mobile Launch Platform/Umbilical Tower
                              CT - Crawler Tractor
                              LC39A or LC39B - Launch Pads
                              • hellnbakH
                                hellnbak
                                How many whiskies did you say you had? ๐Ÿ˜ฒ
                                • Paul RussamP
                                  Paul Russam
                                  Mr James is quite right.
                                  I got the as built drawings for the Mobile launch platform/Launch umbilical tower for the SaturnV, the scale of it is just fantastic. 78 pages of what you see below!
                                  I've seen a few models but I fancied doing my own, There are lots of photos of the Saturn V but finding good reference photos of the launch platform is hard work.
                                  Paul Russam
                                  • hellnbakH
                                    hellnbak
                                    You'd think that with something this massive they could have sprung for something a little beefier than those '49 Buick shock absorbers ๐Ÿ˜†
                                    • Paul RussamP
                                      Paul Russam
                                      If I've understood it right, they're adjusters. the top and bottom connectors are threaded into the centre section and it's 8 sided like a big nut. Turning it with what must be the mother of all spanners would enable them to adjust the tie down's angle. That part of the drawing was hard to read.
                                      There are 2 ball joints (one at the top, one at the bottom) within the tie down post. I asume they'd have to adjust the tie downs position due to thermal expansion etc on the Launch platform.
                                      Paul Russam
                                      • leedeeteeL
                                        leedeetee
                                        This project is staggering. Wow. I have thoroughly enjoyed seeing all your fabulous WIP shots. Thanks for posting.
                                        • urgenU
                                          urgen
                                          @paul russam said:
                                          Last nights render.....
                                          ...O-O-o! ๐Ÿ˜ฒ
                                          ...Great,really Great!Thanks Paul! ๐Ÿ‘
                                          --pupil forever...------
                                          • Paul RussamP
                                            Paul Russam
                                            Here's this weekend's panorama. 64 hours on a Core2 Quad 2.5Ghz 4000x2000 jpeg
                                            https://lh4.googleusercontent.com/-Uamkg-K_r_c/T0IFHRJc37I/AAAAAAAAGHQ/QikYoZSLK5I/s800/Test23-Easy09-Exp18.jpg
                                            Links to full size 4000x2000 jpeg
                                            Link to panorama on Pixeet
                                            Paul Russam
                                            • 2 / 2
