    Altared Images
    36 Posts 15 Posters 7.0k Views 15 Watching
      Roger
      @paul russam said:
      It may seem like I've only ever worked on this project bit its not true, ITS NOT TRUE I TELL YOU!!! ๐Ÿ˜„
      They've either been for too boring or in the case of the prison far to sensitive to show.
      This is a little something I'm having fun with for my own self gratification, can you guess what it is?
      You said it yourself. It is a self-gratification machine. ๐Ÿ˜ฎ
      http://www.azcreative.com
      • hellnbakH
        hellnbak
        ๐Ÿคฃ
        • Paul RussamP
          Paul Russam
          I've just kicked off this weekends panorama, I've set Twilight to save it every 10mins to my dropbox folder.
          Here's a link to it:
          4000x2000 jpeg panorama
          Twilight tends to create big jpegs (opening and resaving them usually halves their size) so be warned if you chose to view it. It could be 10Mb or more hence why I've done a URL link and not an IMG link here.
          As I said it'll be updated every 10mins so it'll get more refined as time goes on.
          Paul Russam
          English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
            mac1
            well head or blowout preventer
            • FletchF
              Fletch
              @paul russam said:
              Here's a link to a very rough YouTube vid showing the Pixeet app on my iPad:
              very very ๐Ÿ˜Ž โ—
              Fletch
              • Paul RussamP
                Paul Russam
                @roger
                Only in a darkened room
                @Fletch
                You try holding an iPhone next your your ear with an iPad at arms length and spinning on the spot. If it wasn't for the fact that I'd sensibly had my 11am whisky it'd been a lot worse. ๐Ÿ˜‰
                @mac1
                Nope
                I'll give you a clue, Inside the VAB an S-IC, S-IIB, S-IVB, LM,SM and CM are stacked on an MLP/LUT and then taken using the CT to either LC39A or LC39B whereupon the CT parks the MLP/LUT upon 6 of the things above
                Come on I'm practically drawing you a picture ๐Ÿ˜‰
                Paul Russam
                • Bob JamesB
                  Bob James
                  Tiedowns for the Mobile Launch Platform
                  VAB - Vehicle Assembly Building
                  S-IC, S-IIB, S-IVB, LM,SM and CM - Vehicle stages
                  MLP/LUT - Mobile Launch Platform/Umbilical Tower
                  CT - Crawler Tractor
                  LC39A or LC39B - Launch Pads
                  • hellnbakH
                    hellnbak
                    How many whiskies did you say you had? ๐Ÿ˜ฒ
                    • Paul RussamP
                      Paul Russam
                      Mr James is quite right.
                      I got the as built drawings for the Mobile launch platform/Launch umbilical tower for the SaturnV, the scale of it is just fantastic. 78 pages of what you see below!
                      I've seen a few models but I fancied doing my own, There are lots of photos of the Saturn V but finding good reference photos of the launch platform is hard work.
                      Paul Russam
                      • hellnbakH
                        hellnbak
                        You'd think that with something this massive they could have sprung for something a little beefier than those '49 Buick shock absorbers ๐Ÿ˜†
                        • Paul RussamP
                          Paul Russam
                          If I've understood it right, they're adjusters. the top and bottom connectors are threaded into the centre section and it's 8 sided like a big nut. Turning it with what must be the mother of all spanners would enable them to adjust the tie down's angle. That part of the drawing was hard to read.
                          There are 2 ball joints (one at the top, one at the bottom) within the tie down post. I asume they'd have to adjust the tie downs position due to thermal expansion etc on the Launch platform.
                          Paul Russam
                          • leedeeteeL
                            leedeetee
                            This project is staggering. Wow. I have thoroughly enjoyed seeing all your fabulous WIP shots. Thanks for posting.
                            • urgenU
                              urgen
                              @paul russam said:
                              Last nights render.....
                              ...O-O-o! ๐Ÿ˜ฒ
                              ...Great,really Great!Thanks Paul! ๐Ÿ‘
                              --pupil forever...------
                              • Paul RussamP
                                Paul Russam
                                Here's this weekend's panorama. 64 hours on a Core2 Quad 2.5Ghz 4000x2000 jpeg
                                https://lh4.googleusercontent.com/-Uamkg-K_r_c/T0IFHRJc37I/AAAAAAAAGHQ/QikYoZSLK5I/s800/Test23-Easy09-Exp18.jpg
                                Links to full size 4000x2000 jpeg
                                Link to panorama on Pixeet
                                Paul Russam
                                • leedeeteeL
                                  leedeetee
                                  Could I ask what the stats for this model? (Apologies if I've missed it elsewhere).
                                  Faces/mb etc?
                                  • Paul RussamP
                                    Paul Russam
                                    Edges : 4,573,393
                                    Faces : 2,120,510
                                    Components : 35,953
                                    Groups : 6,100
                                    Comp Definitions : 958
                                    Layers : 63
                                    Material : 256
                                    Zipped : 41.5 Mb
                                    Paul Russam
                                    • jo-keJ
                                      jo-ke
                                      really great stuff. Nice idea with the panoramas. Very inspiring!
                                      I have some problems with twilightrender with huge models and big imagesizes. Mostly twilightrender gets stuck.
                                      http://www.zz7.de
                                      • Paul RussamP
                                        Paul Russam
                                        I'm using XP and this model wouldn't render, it would get through the processing stage and then go straight to Complete without rendering anything. I then found this thread on the Twilight forum and it enabled me to have enough free memory to render it.
                                        Additionally I used ThomThom's CleanUp plugin a extensively to purge a lot of waisted faces/edges etc. At one point I copied the model several times and in each one cleared out everything except floors or walls or windows etc. I then cleaned that particular model of everything (layers/styles/scenes/edges/faces etc etc)and then reimported it into a clean SketchUp file. This got rid of a lot of stuff I didn't even know was in there.
                                        I thought I'd been efficient in my modeling but CleanUp showed just how wrong I was. ๐Ÿ˜ณ
                                        Paul Russam
                                        • Paul RussamP
                                          Paul Russam
                                          Tonight's Render
                                          3000x2250 Image looking from altar towards front doors with depth of field effect to focus eye on roundal in front of altar (I hope ๐Ÿ˜„ )
                                          Click to View Progress - Updated every 10mins
                                          Edit:
                                          Instead of creating a new post, I'll just edit this one.
                                          Here's the finished render and the pure SU view:
                                          https://lh5.googleusercontent.com/-nA0Oup8RJ4Y/T0Nb9g7fdEI/AAAAAAAAGHY/0y-yEFEp2Fg/s700/Test24-Easy09-F14-Exp20.jpg
                                          https://lh3.googleusercontent.com/-A2n560wyWVA/T0NcGf9qtNI/AAAAAAAAGHc/NtlFCJ7LifE/s700/Test24-SU.jpg
                                          Something is not quite right with the rendering, if your look at the roundal on the floor you can see 1/4 of it look different, I've make it in 4 quarters so I could get 4x1200pix images for the texture(s).
                                          In every other view its fine, I changed nothing and all the settings match in the 4 materials so I'm not sure what's going on.
                                          Paul Russam
                                          • 2 / 2
