    200 .skp files in my plugins folder?
    5 Posts 3 Posters 453 Views 3 Watching
    • peter_shawP Offline
      peter_shaw
      I just cleaned up my \plugins folder, and discovered over 200 .skp files, named 1.skp, 2.skp, 3.skp etcetc. total size was over 1,2 gb. what the hell? anyone knows what these files are doing in there?
        Did you open any to see what they are?
          If you are using a SKP that is located on an external-device [memory-stick etc] or perhaps a network drive with a slow connection, then when Sketchup tries to make AutoSaved files etc it sometimes fails, so instead it makes a 0.skp, 1.skp etc [i.e. an unused 'name'] in the 'current working directory' [probably intending to rename the file when it's done but never succeeding], the cwd in your case seems to be 'Plugins ? [if you type Dir.pwd in the Ruby Console it should tell you that].
          These 'backups' are not needed, but do check that the original SKP files have been properly saved onto the 'device' before deleting them...
          ๐Ÿ˜•
            peter_shaw
            TIG, i'm indeed saving the files on a network device. thanks for explaining, interesting to know how that happened ๐Ÿ˜„
            btw, what is cwd? autosave folder?
            Dir.pwd
            C;/Program Files/Google/Google SketchUp 8/Plugins
              Just an acronym...
              cwd = Current Working Directory
              just as
              pwd = Print Working Directory
              Dir.pwd usually returns the Plugins folder... BUT some auto-loading scripts change the cwd to another folder, so you can never be certain - but here my guess proved right ๐Ÿ˜ฎ
