    Using more than one component as profile?!
    3 Posts 2 Posters 202 Views 2 Watching
    • N Offline
      NickGenerator
      My plan was to use mirrored components, especially because I wanted curves and corners in my profiles.
      Unfortunately neither Tig's Extrusion Tools nor Fredo's Curviloft treat/accept those four curves as one being inside "their" components.
      What can I do here??
        Select the component-instances [hold down Ctrl to add to the selection or use a fence] and right-click context-menu > Explode to explode them back to geometry [also works on groups]; alternatively select them in the Outliner so they highlight in the Model too then Explode them...
        Do NOT Explode the Curves - you need those later !
        Now you have Curves that you can select for the tool[s] all in the same context...
        • N Offline
          NickGenerator
          Thank you, Tig. If you are ever bored, being able to select those (components) without exploding would be a really nice feature.
