    Skinning of Shapes (Curviloft)
    3 Posts 2 Posters 879 Views 2 Watching
    • N
      NickGenerator
      Is it possible to force Curviloft to treat this as 4 edges and create a skin here with "Skinning of Shapes"? Because I really tried hard, but didn't get it... (I attached an .skp, too.)
      skinning.skp
      • TIGT
        It should be... it's normally very robust.
        But I too am having issues getting a good result 😕
        This version was made using my ExtrudeEdgesByRails tool, with the profile/melding-profile being the shorter curves and the longer sweeping curves the rails... seems to work OK ?Capture.PNG
        • N
          NickGenerator
          @tig said:
          This version was made using my ExtrudeEdgesByRails tool ... seems to work OK ?
          The mesh it generates is very clean and nice, but if you look at it in side view it is not what you always want.
          But I found out that Curviloft works with a little workaround. (One edge, no vertex in the center.)
