    [REQ] Find this material
    7 Posts 4 Posters 328 Views 4 Watching
    • soloS Offline
      solo
      Occasionally I get a rouge material that appears in my material editor but to the life of me I cannot find it in the model, normally I just delete it only to later find out it was actually an important mat in an obscure spot that indeed needed to be there, so I was wondering if a plugin exists that I can click on a material in the material editor and select 'find this material in model' and it would hi-lite it so I can confirm it or delete it without fear.
      Sometimes it's a material applied to a back face and requires deletion, I just need to confirm it before deleting.
      Very needed for models from the 3DWH.
      http://www.solos-art.com
      • soloS Offline
        solo
        @massimo said:
        Well you can right click on the material in the "in model" materials panel-->select and then switch, for example, to x-ray mode in order to view better the selected material. Just a thought. πŸ˜„
        I know that, however in some big models with lots of materials finding that material in the first place is difficult, hence the need to find it.
        • massimoM Offline
          massimo Moderator
          Well you can right click on the material in the "in model" materials panel-->select and then switch, for example, to x-ray mode in order to see better the selected material. Just a thought. πŸ˜„
            Only if the entities with the material is in the current context...
              That would work but only in the current context and once a material is inside a group only, it won't select it.
              I do not know if this plugin would dig down to groups:
              http://forums.sketchucation.com/viewtopic.php?t=31378
              TT, when you are at it (and beat me...) Your Selection toys can select entities inside groups. Would it be possible to extend it with a material selection option, too?
                It would... though I have since found that cross context selections is asking for trouble. SketchUp doesn't like it much.
                I'm thinking that it might be better with a tool like Solid Inspector that would highlight the geometry in that manner.
                  Well, in this particular case it would indeed be better.
