    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 411.2k Views 80 Watching
      Anton_S
      @guanjin said:
      Great, my Windows XP
      There is a problem, set the shortcut key to display the menu bar is invalid πŸ˜’ πŸ˜’
      [attachment=0:28de3p4w]<!-- ia0 -->66666666666666.gif<!-- ia0 -->[/attachment:28de3p4w]
      Yes, it should be invalid!!! Wanna know why? Well, I explained it a bit on first post. Its just the way of how shortcut pereferences works. Shortcut Pereferences script tends to select the menu bar items once the shortcut key is pressed. But, When the menu it self is no more there, Sketchup can no longer select the items. What's weird is that once u hide the menu bar other shortcuts that were set by sketchup (Ex: "s" - scale, "p" - push) work, but once u click the shortcut that belong to "show menu bar," all shortcuts stop working. Show/hide menu bar was just for fun, so yeah don't use it. Though, I'll try to fix that issue too.
      • guanjinG Offline
        guanjin
        Thank you! Can not be restored, the canceled, resulting in unnecessary trouble πŸ˜’
        I come from China, is to learn
        • U Offline
          unclex
          only fullscreen can work
          and
          suggest to change the plugin menu from β€œPlugins” to β€œWindow"
            Anton_S
            @unclex said:
            only fullscreen can work"
            Is that about the updated or the first version?
            • U Offline
              unclex
              updated
              @ SU8.0.11
              @ win7 pro patched 4GB
                Anton_S
                @unclex said:
                updated
                @ SU8.0.11
                Is it 32 or 64 bit processor?
                • U Offline
                  unclex
                  WellDone
                  Win7X86Pro
                  Su8.0.11Pro
                  except Toolbar, all worked
                  and i can not dare try the Menu Option, if i close it, how reopen it ??
                    Anton_S
                    @unclex said:
                    WellDone
                    Win7X86Pro
                    Su8.0.11Pro
                    The toolbars option is to hide toolbars that are not embedded into SU controll bar, meaning the onece that have a border and caption. They should work.
                    And yes, hide menu option is just for fun, There is no way of unhidding it through shortcut pereferences. Though you could set a timer or call a command to unhide it. Just read throuh posts and you'll figure it out.
                    Have you checked if show/hide "controll bars" work when SU is maximized or full_screen? If didn't, then can you please check that and reply.
                      Anton_S
                      updated february 10th, 2012
                      Now works on windows 7 too!!! Well, read the 1st post for an info. πŸ˜‰
                      Thankyou, for your replies and comments!!! They really improved the plugin plus my English. πŸ˜„
                      Somehow, therefore, I don't strugle at the english essays anymore... ❗ 😍
                      • CadFatherC Offline
                        CadFather
                        Hi Anton and Thank You - this is a really great plugin πŸ‘ β˜€
                        is there a way that i could chain a few of those commands?
                        say i press F12 and sketchup goes full screen + no controls + no status bar + no scene bar.. etc?
                          Anton_S
                          Well, rightnow threre isn't, but I'm planing to add two new command items to "window/settings". One will be "chain multiple" and the other "set multiple". The "chain multiple" will open a dialog box with a checkbox for each command ("full screen", "controll bar(s)", "status bar"...). The "set multiple" command item will show/hide the items that are checked in the dialog box. Like if "full screen" and "status bar" is checked, the "set multiple" command will toggle sketchup between "full screen" and show/hide "status bar".
                          I already started doing that, but not having knowledge in html, javascript, css, and other will slow down the release of new version.
                            CadFather
                            sounds perfect Anton..looking forward to it..
                            • P Offline
                              pololo
                              For win7 64bits .... please!! πŸ˜’
                                What do you mean by this? It should work as is. Nothing special about Win7 64bit. Do you get errors or anything when you try to use/load/install it?
                                • Rich O BrienR Online
                                  It works on Win7
                                    It's in Windows > Settings
                                    • P Offline
                                      pololo
                                      Hi Thom!! DoesnΒ΄t work on win 7 64 bits, not even in the plugins menu.
                                      Dont load in my win7.
                                      Has anyone tested it on windows 7 64 bits?
                                      I use Sketchup 8/win64 bits
                                        It's worth re-reading the plugin description if you experience problems.
                                        (I modified the text colour to a darker grey as it was rather invisible with light grey on white background... )
                                        • P Offline
                                          pololo
                                          Thanks Thom, Rich!!
                                          I appreciate your help, thank you very much!!!
                                          • N Offline
                                            newrui
                                            Hi Anton, is it possible to make this work with Macs? Perhaps use Lion's full screen feature? SU is desperately in need of window/toolbar management under Macs... Thanks!
                                            • 14
                                            • 15
                                            • 2 / 15
