    Stuck!!!
    16 Posts 5 Posters 827 Views 5 Watching
      stewmabe
      Hi all
      New to the forum, just end of my first week on skup everything going well but my model seems to have turned into part wireframe, edges are visiblw as are faces but the face are transparent! it happened when i zoomed extents! any ideas how to undo this?
      stew
      • leedeeteeL Offline
        leedeetee
        Hi and welcome!
        Make sure your styles toolbar is on by going to VIEW > TOOLBARS and making sure STYLES is ticked.
        On this toolbar are 7 options for how your model appears. It is likely you have clicked on "x-ray". Click on "Shaded" or "Shaded with textures" to get your model back to how you want to view it.
        If there are no edges on, turn them on clicking VIEW > EDGE STYLE > EDGES.
          stewmabe
          thanks leedeetee,
          have tried that but model still remains the same, faces are kind of there but translucent
            leedeetee
            Could you upload the model?
              Post a screenshot showing your styles settings and layers
                stewmabe
                oh Gawwwwwwdd
                Cheers guys,
                how do i upload a model? can i do it to this site?
                  there's an upload button under the reply box when replying. files must be 4mb or less
                    stewmabe
                    Doh
                    thanks for that!
                    phew! thanks guys here it is
                    • pbacotP Offline
                      Try setting Camera to Perspective, View Extents, then zoom in on your model.
                      Don't know why it was like that though.
                        stewmabe
                        Ah easy as that!
                        It worked, all back to normal.
                        I suspect strong case of 'user error' may have been the culprit!
                        Thanks guys
                        Stew
                          You have a 2d plan floating nearly 4 million mm's above the house
                          Delete it or move it down within the earth's weather system
                            leedeetee
                            Came back from making a hot chocolate to find your sorted. Nice one. πŸ˜„
                              stewmabe
                              yes will do,
                              I know its there just moved it out the way when i was modelling the stairs
                              again chaps cheers
                                stewmabe
                                Excellent! enjoy the hot chocolate.
                                  SketchUp doesn't like things way off in the distance. Bring that plan down and reorganize the layer to help with visibility
                                  @Lee
                                  Hope you plan to run that off πŸ˜‰
                                    The 2d import is located very far above z=0, which doesn't help... BUT the 2d plans were obviously imported from a CAD file [dwg/dxf?] and they contain some rogue geometry that's miles off.
                                    If you edit that component [double-click it], then use edit > 'select all' [ctrl+A], and then deselect the visible parts by using select+fence whilst holding shift+ctrl, then press 'delete', the 'unseen' CAD file's rogue geometry that's a zillion miles away [and totally useless to you anyway] is removed... then the whole thing works OK with the wall faces displaying properly etc etc.
                                    The extents of the model were so distorted by this issue that SUp couldn't properly calculate the visible geometry, so faces went weird... πŸ˜•
