    Help! BezierSpline v1.4 won't show up!
    8 Posts 4 Posters 669 Views 4 Watching
    • W Offline
      witzquito
      It shows up in my plugin folder, but when I restart SU8, it doesn't show up in the extensions, or anywhere else, for that matter!
        Have you installed as per the instructions on the download page?
          1. Download and Open the archive
          2. Select All (Ctrl A)
          3. Extract into the Sketchup Plugin Directory
          4. Answer YES to overwrite all existing files if any
          The footprint in the SU Plugin Directory must be:
          bezierspline.rb
          LibTraductor.rb (dated 10 Nov 10)
          BZ_Dir_14 folder
          On Mac the SU plugin directory should be:
          Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins
          IMPORTANT: You should delete any BZ__***.rb files that may exist in the SU Plugins folder. You should also delete the subfolder BZ_Dir if it exists. You can also delete the subfolder BZ_Dir_13.
          CAUTION: NEVER rename or move files from their folders. If you are unsure of your unzip operation, do it in a neutral folder and check that you reconstruct the right footprint. Then transfer the folders and files to the SU Plugin Directory.
          • W Offline
            witzquito
            Yes. Everything appears as it should!
            My other plugins work perfectly, and I have had no problems.
            • W Offline
              witzquito
                bezierspline.rb
                BZ_Dir_14 folder
                  No! It doesn't. Your screen shot clearly shows the installation does not match what Rich told you and what it says in the first post of the thread where you got the plugin.
                    It seems that whatever is in your bzier spline... folder, should be copied one level higher (straight under the plugins folder). You unzipped the archive keeping its "wrapping folder" instead of moving the content of that folder straight into the plugins folder.
