    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Mysterious Bug [followme related]
    30 Posts 4 Posters 1.1k Views 4 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      Alright replace the load loop with this ...
        # run when file loads
        prevdir = Dir.getwd
        Dir.chdir Sketchup.find_support_file("Tools")
        tools = Dir["*.rb"]
        Dir.chdir(prevdir)
        if ( tools & $LOADED_FEATURES == tools ) &&
        Sketchup.active_model &&
        Sketchup.active_model.active_entities
          UI.start_timer(2.0, false){ LineA.create_line }
        else
          timer_LineA = UI.start_timer(2.0, true){
              UI.stop_timer(timer_LineA)
              LineA.create_line
            end #if
        tools = nil
      I'm not here much anymore.
        Dan Rathbun
        And here's a version that makes sure the Tool Stack is ready ...
          prevdir = Dir.getwd
          tools = Dir["*.rb"]
          Dir.chdir(prevdir)
          Sketchup.active_model.active_entities &&
          Sketchup.active_model.tools.active_tool_id != 0
          else
                LineA.create_line
              end #if
          tools = nil
          Let's step back to the very beginning...
          Do you need this script to run automatically EVERY time EVERY SKP opens?
          A. Yes.
          Why for goodness sake ???
          A. No.
          Then what's the problem?
          If it runs from a menu/toolbar then everything will be loaded by the time you think about using it anyway. Just do NOT include the code that runs it as it loads and everything is cushty!
          πŸ˜•
            Dan Rathbun
            Because he's generating ruby scripts (that build geometry,) from a C# program, which reads XML data.
            A batch mode use of Sketchup.
            He's not that good with Ruby, or else he could use Ruby's XML libraries directly.
            And I do have an API request in for an AppObserver "onReadyState" callback method.
              Well, I tried the snippet - installed in my Plugins folder - now executing the command. It splatted. But wrapping the command in a timer that delay the operation with two seconds - no splat.
                Dan Rathbun
                The processing of the Tools dir must complete, so that the menus and toolbars can all be built and displayed.
                  Isn't he doing it arse-before-face as we say in the UK ?
                  Open Sketchup.
                  Start_operation.
                  Run the external 'tool'...
                  Load the objects in turn, each one as an individual component.
                  When all objects are done Export those objects in turn as separate SKPs.
                  Abort_operation.
                  Close Sketchup [no save].
                  That way nothing relies on something else 'opening in time' ?
                    Dan Rathbun
                    We'll, he knows C#, and not much of Ruby.
                    Instead of using Sketchup in a hacked batchmode... he or someone needs to wrap the C++ Interfaces for SKPWriter.DLL for C#. (Likely someone has already done it.) Any way it would be better to directly create skps.
                      Chris88
                      THANKS to all for your efforts!
                      Now it works!!! it's slower than before, but it runs and that's the main thing!
                      @Dan: Thank you, you're the best! ^^
                        Dan Rathbun
                        No problem...
                        Just a note that the disposal of the tools filename array needs to be inside the conditional true blocks. (Otherwise we might get an error with the & method if tools gets set to nil, prematurely.)
                          prevdir = Dir.getwd
                          tools = Dir["*.rb"]
                          Dir.chdir(prevdir)
                          prevdir = nil
                            tools = nil
                          else
                                tools = nil
                                LineA.create_line
                              end #if
                        • 2 / 2
