    Frontside and backside colour
    9 Posts 3 Posters 629 Views 3 Watching
    • C
      ChrisKa
      Hello,
      if I import a COLLADA-File I can change the (frontside) colour with the following Code:
      Sketchup.active_model.active_entities.each{|e|e.material="green"};
      I want to do the same with the backside of the areas, but this Code doesn't work:
      Sketchup.active_model.active_entities.each{|e|e.back_material="green"};
      Can somebody help me why this Code doesn't work?
      Thanks,
      Chris
      • thomthomT
        You're getting errors, right?
        Only faces have the .back_material method - so when you iterate a whole entity collection you're also iterating over edges, guides etc. You need to ensure you're applying back material to only faces.
        If that is not the case - then you need to provide more info on what you are doing and exactly what "isn't working". (Errors or unexpected results. Sample models help.)
        • C
          ChrisKa
          Hy thomthom,
          this is my COLLADA-File: COLLADAfile.zip
          The frontside colour I can change. This you can see on the file "change_frontside_colour.jpg".
          And now my problem is that I can't change the backside colour!
          "change_backside_colour_ERROR.jpg"
          Thanks a lot for your help,
          ChrisKa
          COLLADAfile.zip
          • thomthomT
            That is it - you are trying to call .back_material on a ComponentInstance.
            You need to ensure you got a Face.
            Sketchup.active_model.active_entities.each{|e|e.back_material="green" if e.is_a?(SketchUp::Face)};
            But note that if the geometry of yours is inside a group or component your code won't dig into the nested groups/components. As you have the code now, the currently active context (open component) must be the one containing the faces.
            • C
              ChrisKa
              Sorry, but I don't understand.
              Do you mean that I have to explode the component for working this code.
              Is there a possibility that I can change the backside-colour inside the component like the frontside-colour?
              • thomthomT
                For that simple example you provided you only need to open the component before you run the script.
                But I don't know the bigger context where you use this.
                Here is a snippet that process the entire model:
                <span class="syntaxdefault"><br /></span><span class="syntaxcomment"># Process entities in the root model context<br /></span><span class="syntaxdefault">for e in Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />  next unless e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">SketchUp</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"green"<br /></span><span class="syntaxdefault">  e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">back_material</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"green"<br /></span><span class="syntaxdefault">end<br /></span><span class="syntaxcomment"># Process all groups and components<br /></span><span class="syntaxdefault">for d in Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions<br />  next if d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">image</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">  for e in d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />    next unless e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">SketchUp</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"green"<br /></span><span class="syntaxdefault">    e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">back_material</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"green"<br /></span><span class="syntaxdefault">  end<br />end<br /></span>
                • C
                  ChrisKa
                  I would like to import the COLLADA-File with the "Ruby-Console".
                  The code should be in one line.
                  Do you have an idea?
                  Thanks,
                  Chris
                  • TIGT
                    Your code currently makes everything in the model.active_entities have the specified material.
                    Because the imported geometry arrives inside a component your code gives that material to the instance - NOT its contents.
                    Faces inside a component [or group] that have no material applied to them [front or back] will initially show in the default material.
                    Then if you give the 'container' a material then those faces will be displayed as if they had that material, BUT they are actually still in the default material.
                    If you want to give a material to the faces inside a component you need to use something like this.
                    Assuming that you want every face in the model to use that material...
                    Sketchup.active_model.definitions.each{|d|next if d.image?; d.entities.each{|e|next unless e.class==Sketchup::Face; e.material="green"; e.back_material="green"}}
                    To ALSO process any faces in the model's entities use this:
                    Sketchup.active_model.entities.each{|e|next unless e.class==Sketchup::Face; e.material="green"; e.back_material="green"}
                    You can obviously mess around with materials and so on...
                    You could even limit the change to the imported component [its component name ISN'T the same as the dae file so we must get all components before we start and then find which one was [or ones were] added by the import]...
                    ds=Sketchup.active_model.definitions.to_a; ###add your importer code here...; ds=Sketchup.active_model.definitions.to_a-ds;###ds is an array of just the imported component[s]; ds.each{|d|d.entities.each{|e|next unless e.class==Sketchup::Face; e.material="green"; e.back_material="green"}}
                    • C
                      ChrisKa
                      Thanks a lot for your help.
                      Now this code is very helpful for me!
                      ChrisKa
