    Bad glass window
    renderpluginsextensions
    6 Posts 4 Posters 781 Views 4 Watching
    • john2J Offline
      john2
      im trying to render a louvered window in sketchup. the glass is coming as pathetic. i edited the sketchup blue translucent material to reflective [fresnel]. the effect isnt coming as that of a glass. what is wrong?
      LOUVRD WINDOW SCF.skp
        1. Your Diffuse layer isn't fully transparent. That will make the window appear somewhat dense.
          If you want a tint to your window you can have some opacity, but not a whole lot. (And this is only if you have glass made out of a single face - "fake glass")
        2. Your glass has a refraction layer. The refraction layer can be used to tint your glass with a colour if you like, and more realistic. But you need a "thick" glass. You need two surfaces - otherwise it'll look like what's behind the glass is inside a solid lump of glass. This is due to how refraction breaks the light beam.
        3. You have set the multiplier of your reflection map to 4 - not sure why - or how much it affects anything. But I don't quite see the need for that.
        4. Consider that what you see of glass is mostly reflection - so when you render glass in an empty scene you're not really going to be getting much of out. Reflections only really work well when they have something to reflect.
        • V Offline
          valerostudio
          Gotta have something to reflect too! Use an HDRI in your BG slot under environment. I have attached a glass material I use a lot.
          A_Matts Best Glass.zip
          • N Offline
            nomeradona
            check this out. http://www.sketchupvrayresources.blogspot.com/2011/07/vray-sketchup-glass-material.html
            visit my blog: http://www.nomeradona.blogspot.com
            • V Offline
              valerostudio
              We can know attach VISMATs!
              A_Matts Best Glass.vismat
