    [Plugin] Slicer5
    338 Posts 83 Posters 375.1k Views 82 Watching
      boramille
      @tig said:
      Run it with the Ruby Panel open and report error messages, if any...
      Assuming that it has worked - use the Layers-Panel to switch your layers’ visibility on/off - the original object that you chose to slice is reassigned to layer “SLCR-HIDN”, which is then ‘hidden’, so you can see the results clearly…
      Other layers used by the various slices also have names that start “SLCR-…”, so you can also toggle these on/off as needed…
      It is still not appear when I already switch the visibility on.
        Please re-post, attaching the SKP files, 1 before your slice it and 2 after you slice it.
        So we can look at the possibilities...
          alexakaczor
          Is it possible to get this for sketchup 2019?
            Yes. It already is compatible with SU2019. Right here: https://sketchucation.com/pluginstore?pln=TIG_Slicer
            Install the Sketchucation Extension Store tool and let it install Slicer and other extensions for you directly.
              alexakaczor
              Is it possible to get this updated to be compatible with SKP 2019?? Thanks!
                It already is compatible with SU2019. I just made an example in SU2019 to show you.
                • N Offline
                  Nudornn
                  thxxxxxxxxxxx
                  • K Offline
                    kulibin
                    Hi!
                    Can you add dogbones
                    like this https://fablab.ruc.dk/more-elegant-cnc-dogbones/
                    and chamfer cut for start of joint?
                      misterdee
                      Hello TIG
                      Great PlugIn, thank you very much!
                      However, when I slice with it, arcs are converted to edges and the sliced shape loses the nice curves.
                      Is there any way to prevent this?
                      Or an easy way to iron this out afterwards?
                      Thanks in advance
                      Best regards
                      misterdee
                        Can you share an example .skp file that shows what you are seeing?
                        What version of SketchUp are you actually using? Your profile says 2018 Free/Make but there is no such version.
                          The slice is by its very nature a cut through a 3d-object.
                          It ignores any 'curves' that might result and substitutes a segmented solution.
                          If the surface you are cutting is for example a cylinder with 24 facets from its original circle the cut geometry will have 24 segments.
                          So if you are cutting objects where you have control of their 'faceted-ness' from an early stage, then a cylinder with 72 facets will obviously result in a smoother slice...
                          • P Offline
                            pshearn11
                            Hello,
                            I have installed Slicer and enabled it. When I try to use it I get an error message that reads "No selection!" This happens on all of the tool options in the Slicer toolset.
                            I have tried installing other plugins and extensions and they work fine.
                            Any help would be greatly appreciated!!!
                              Did you select the object you wanted to slice? You have to select a component or group in order for Slicer to have something to do.
                              • P Offline
                                pshearn11
                                DOH! Thanks!
                                  BCISTEVIE
                                  Do you know if this plugin will work with sketchup pro 2021?
                                  thanks in advance.
                                    Yes. It works fine in SketchUp 2021 Pro.
                                    BTW, please correct your profile. It says you are using 2021 Free/Make which can't be.
                                      sftc
                                      Hi TIG,
                                      How do I contact you to make a custom plugin?
                                      my contact email matt[at]sftc.com.au
                                        To discuss something like this send me a Private-Message outlining what it is you want to do, I'll then get back to you with some ideas...
                                          sftc
                                          Hi TIG,
                                          This website isn't the most user friendly how do I even send you a private message
                                          ? Could you email me matt[at]sftc.com.au
                                            No - I will not become involved in email discussions, except in exceptional circumstances...
                                            But it is NOT difficult to PM here...
                                            Also, please stop posting your email address publicly - spam-bots will scrape it and you'll get extra spam emails ! I edited your posts' address's @ to an [at] to protect you from this...
                                            It's very easy to do a PM...
                                            Click the Private-Message icon [box?] below my avatar to the left of this message.
                                            In the page/dialog that appears type/edit [or copy/paste] your text, attach files or images etc, as appropriate and then submit it to me.
                                            I'll be notified immediately under my own Message heading, and we can then have a simple to-and-fro conversation, all of which will be 'in private', with you getting notifications when my reply is in your in-box etc...
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
