    [Plugin] Slicer5
    338 Posts 83 Posters 394.1k Views 82 Watching
      The slice is by its very nature a cut through a 3d-object.
      It ignores any 'curves' that might result and substitutes a segmented solution.
      If the surface you are cutting is for example a cylinder with 24 facets from its original circle the cut geometry will have 24 segments.
      So if you are cutting objects where you have control of their 'faceted-ness' from an early stage, then a cylinder with 72 facets will obviously result in a smoother slice...
      • P
        pshearn11
        Hello,
        I have installed Slicer and enabled it. When I try to use it I get an error message that reads "No selection!" This happens on all of the tool options in the Slicer toolset.
        I have tried installing other plugins and extensions and they work fine.
        Any help would be greatly appreciated!!!
          Did you select the object you wanted to slice? You have to select a component or group in order for Slicer to have something to do.
          • P
            pshearn11
            DOH! Thanks!
            • B
              BCISTEVIE
              Do you know if this plugin will work with sketchup pro 2021?
              thanks in advance.
                Yes. It works fine in SketchUp 2021 Pro.
                BTW, please correct your profile. It says you are using 2021 Free/Make which can't be.
                  sftc
                  Hi TIG,
                  How do I contact you to make a custom plugin?
                  my contact email matt[at]sftc.com.au
                    To discuss something like this send me a Private-Message outlining what it is you want to do, I'll then get back to you with some ideas...
                      sftc
                      Hi TIG,
                      This website isn't the most user friendly how do I even send you a private message
                      ? Could you email me matt[at]sftc.com.au
                        No - I will not become involved in email discussions, except in exceptional circumstances...
                        But it is NOT difficult to PM here...
                        Also, please stop posting your email address publicly - spam-bots will scrape it and you'll get extra spam emails ! I edited your posts' address's @ to an [at] to protect you from this...
                        It's very easy to do a PM...
                        Click the Private-Message icon [box?] below my avatar to the left of this message.
                        In the page/dialog that appears type/edit [or copy/paste] your text, attach files or images etc, as appropriate and then submit it to me.
                        I'll be notified immediately under my own Message heading, and we can then have a simple to-and-fro conversation, all of which will be 'in private', with you getting notifications when my reply is in your in-box etc...
                        • T
                          TBoy
                          Mr. TIG
                          Is it possible to make variation of this plugin for cutting object to pieces
                          (For example a big object cut to pieces fitting for 3d printing) ?
                          May be "Slicer" workflow will be OK - cutting in X, Y, Z or any combination of the 3 axes.
                            Look at my "Split to Plane" - which should be able to split your container into parts...
                            https://sketchucation.com/pluginstore?pln=TIG_Split_to_plane
                            • T
                              TBoy
                              OK, but the idea is to make multiple cuts at once.
                              To convert a cube to Rubik's cube - serial cuts in different directions controlling distance between cuts (like slicer).
                                Slicer5 will make cuts in two planes ?
                                I don't understand your issue...
                                • T
                                  TBoy
                                  I'm talking about new plugin that will work similar to "Slicer" but cutting object to smaller parts.
                                  Cutting in 1 or 2 or 3 planes (X, Y, Z) and why not in additional "A and R-planes" like the planes in "Slicer"
                                  "Split to plane" is OK for few splits, but what if I want to make 100 splits(cuttings) equal in height in Z-plane then each of these in Y-plane, and then in X-plane.
                                    With appropriate settings Slicer5 will already split your solid along any 2 planes.
                                    But unfortunately not with 3 planes !
                                    Omitting all gaps/slots/tolerances etc would probably make it simple enough, and then allow a new tool with XYZ slicing...
                                    Unfortunately I don't have the time to do any of this, this year !
                                    The code is readable and you are welcome to try your own new XYZ version...
                                    • T
                                      TBoy
                                      Is this possible with Slicer?
                                      I don't think so, or I obviously miss something in Slicer settings.
                                        The slice settings are XY XZ and YZ
                                        But there's no XYZ !
                                        • T
                                          TBoy
                                          TIG I understand this. The main problem is is not 2 or 3 axes/planes, problem is Slicer is not making actual cutting.
                                          My English is poor and may be I do not use proper words - splitting, slicing or cutting.
                                          So I'll use word dividing.
                                          Slicer is not dividing objects. The idea is to divide in different planes.
                                          In the Lion illustration above every horizontal part has to be separate object. Start with whole Lion as 1 object, applying divide in Z-plane and the result is as in illustration > separate objects instead of 1 whole lion.
                                          Is the idea clear now?
                                            So. your request has little to do with Slicer.
                                            You want a tool which splits an object along the XY and Z planes in one step.
                                            i.e. something like my Split tool, but with more repetitions per plane...
                                            Again, I'm sure it's possible but I am unlikely to create a split-XYZ tool any time soon 😞
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
