    Metro tile help
    10 Posts 5 Posters 637 Views 5 Watching
    • Z Offline
      zumoboy
      Hi just woundering if any one can help me ????
      Please could anyone a make brick pattern tiles below with a black 2mm grout with the tile I have attached ??
        Just edit it in Photoshop or Gimp [free] and add the lines around it yourself, then erase the unwanted outside areas ??
        Use it as a texture for a new material... done...
        I see no difficulties at all...
        What is the issue ??
        Please don't double-post... it doesn't help!
        • Z Offline
          zumoboy
          Thanks Tig
          I am new to this by the way
          I need it to be a brick pattern if you know what I mean ????
          • massimoM Offline
            massimo Moderator
            Something like this?
            • Z Offline
              zumoboy
              I did the gimp download thing and I tried to solve my problem
              God bless massimo and all the best in the new year my friend .
                @zumoboy said:
                Thanks Tig
                Now you say !
                Stretcher-bond, not stacked... πŸ˜’
                Thanks massimo πŸ˜„
                  dsarchs
                  Here's an update that will continue the running bond pattern vertically -- massimo's was tiling, but stacking for the first row.
                  Knowledge is a polite word for dead but not buried imagination.
                  -e.e.cummings
                  • massimoM Offline
                    massimo Moderator
                    Oops...you're right dsarchs. Made that really quickly.
                    • massimoM Offline
                      massimo Moderator
                      An update at higher resolution. πŸ˜„
                      • irwanwrI Offline
                        irwanwr
                        two patterns for two new textures in one page πŸ˜„
                        with a dark grout and a bright one πŸ‘
