    Draw on curve face
    6 Posts 4 Posters 397 Views 4 Watching
    • K Offline
      kshitij111
      Hi ,
      can any body please help me..
      i want to draw lines on curve faces for example if i push /pull round & then i want to draw free hand arc on that its not being possible
      thanks in advance & expecting my answer soon from all genius around here..
      thanks
      Horizon
        Find 'ToolsOnSurface' by Fredo in the Plugins Index...
        This toolset lets you do many of the native operations over a 3d surface...
        πŸ€“
          steved
          Hi, you can use the stamp tool to draw the shape on a flat surface and project it onto the curved or any other shaped surface. You will need to activate your "sandbox if you have not done so. Tools/Sandbox/drape.
          Cheers
          "If I agreed with you on that, then we would both be wrong"
            If you are looking for a 'drape' solution... there is also my 'SuperDrape' tool that is like drape, but can be more consistent AND transfers materials from one group to another...
            • G Offline
              gippolot
              For the sledge hammer approach, I use the push pull tool also, then intersect with model tool.
              I have to do a bit of cleaning up afterwards, but it usually gives a fairly good result. Latest use attached.
              ( I have Fredo's tools though and should probably learn to use them.)
              http://www.flickr.com/photos/53607031@N05/6627192419/in/photostream
              Cheers,
              Andrew
              • K Offline
                kshitij111
                thanks TIG Your tool drapoints worked...
                another help please.....how to apply any one Typical style to my all scenes created in model..or i have to go in each scene & change the model style.......?
