    [Plugin] FredoTools - v4.6a - 21 Oct 26
    464 Posts 123 Posters 843.5k Views 121 Watching
    • J
      JBERGMAN
      To anyone who my be able to help:
      I have tried installing FredoTools and LibFredo6 4.6 and am getting the following error messages upon sketchup startup:
      Error Loading File __loader.rb
      uninitialized constant TraductorError Loading File FredoTools.rb
      uninitialized constant FredoTools::T6Error Loading File FredoTools__ConstructFaceNormal.rb
      undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__CountFacesBySides.rb undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__CurviShear.rb
      undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__MarkVertices.rb undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__RemoveLonelyVertices.rb
      undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__ReportLabelArea.rb undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__ReverseOrientFaces.rb
      undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__RevertCurve.rb undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__ThruPaint.rb
      undefined method `register_plug' for FredoTools:Module
      I see 'LibFredo6 Settings' in the window tab, but cant access anything else. Any suggestions?
      Thanks!
      John
      • TIGT
        John
        You have almost certainly mis-installed it.
        Read back a few posts through this very thread...
        There are very clear instructions in the first post AND in many subsequent ones on how to download and extract the files, and the subfolders of files etc, that this tool needs, including the supporting [linked to] 'Lib' set.
        There are also some other posts regarding the general issues about download/extract/install toolsets, and links - including some to thomthom's 'Simple Plugin Installer' - which would [if you had it installed] avoid all of the headaches that some users like yourself seem to get themselves into with archived file-sets...
        • riekR
          riek
          @rich o brien said:
          There's no FredoTool directory.
          If you read the first post on this thread it clearly shows the footprint....
          http://sketchucation.com/forums/download/file.php?id=79626
          hoi, fredo
          i have installed libfredo6_Dir_46,
          not fredotools
          i tried it, but it wouldn't work
          but the strange thing is,
          curvizard
          and
          curviloft
          didn't run either,
          and now it runs smoothly
          thanks for the plugins,
          i'll try to install the FREDOTOOLS later on
          working with SU is FUN
          • P
            pedroines
            http://technet.microsoft.com/en-us/magazine/ff431742.aspx
            For whatever reasons Windows7 doesn´t allow winrar - in my case - to unpack the files to the plugins directory.
            Follow the above recomendations allowing winrar to run under administrator rights and it´s done.Hope iy helps
            • TIGT
              For whatever reasons Windows7 doesn't allow Winrar - in my case - to unpack the files to the plugins directory.
              Follow the above recommendations allowing Winrar to run under administrator rights and it's done. Hope it helps
              It's not so much the decompression application running as 'admin'... BUT that 'you' have FULL security-permissions to read/write to the Plugins folder [and for that matter Components, Materials and Styles folders too, because from time to time 'you' will want to add files to those...]
              • M
                mingjae
                hi,
                can I copy paste only the FredoTools_CurviShear.rb only to the plugins folder and erase all other plugins from the FredoTools_Dir_12 folder?
                will it load properly like the old day coz i only need the curvishear to make a ramp
                • fredo6F
                  fredo6
                  @mingjae said:
                  hi,
                  NO it won't work.
                  But if you go to the Default Parameters dialog box of FredoTools, you can select which ones would appear in the icon toolbar and in the contextual selection menu.
                  Fredo
                  • pbacotP
                    I had Remove Lonely Vertices in my context menu. This has recently disappeared. Is there some trick to get it into the context menu?
                    Thanks, Peter
                    • fredo6F
                      fredo6
                      Strange,
                      Just in case, go to the Default Parameters dialog box because this is where you can enable or disable the tools of FredoTools in the toolbar and in the contextual menu.
                      Fredo
                      • pbacotP
                        😳 I didn't realize it was under the FredoTools submenu... it used to be different right? Or am I imagining?
                        Thanks for the help. Now I have this oft-used function again!
                        • fredo6F
                          fredo6
                          @pbacot said:
                          :oops: I didn't realize it was under the FredoTools submenu... it used to be different right? Or am I imagining?
                          Well! It is like this because the real estate of the contextual menu is precious.
                          But of course, it is less efficient.
                          Fredo
                          • A
                            AsiaStarArt
                            谢谢你
                            Thank
                            • A
                              asaavedra
                              Hello, I love Freddo plug ins, but I installed SketchUp 13 and these plug ins do not work ... you plan to make it compatible soon??
                              • Alan FraserA
                                Alan Fraser
                                They do work. Update your Fredo6 Library file.
                                3D Figures
                                • R
                                  ruggero56
                                  Devo studiare tutto in inglese, Fredo!! Ma la installazione è stata perfetta! Complimenti e grazie! 😄
                                  • D
                                    davi
                                    thank you very much!
                                    • J
                                      jumboojum
                                      Thank you so much sir 😍
                                      • T
                                        tolson68
                                        Fredo,
                                        I have installed Sketchup 2013 Make on a Linux instance and it seems to be working well. Unfortunately I have a problem loading FredoTools 1.2a. The error message I receive is:
                                        Error Loading File C:/Program Files/SketchUp/SketchUp 2013/Plugins/FREDOTOOLS_Dir_12/__loader.rb
                                        can't convert nil into String
                                        I have tried disabling my other plugins to isolate the cause and then adding them back one at a time and when FredoTools is enabled I start having this problem. I'm happy to assist you in any tracing, since I'm aware that SketchUp itself is not supported on Linux. This is a brand new install and all plugins packages have been downloaded within the past 24 hours.
                                        I am also encountering the same problem in Sketchup 8 on the same machine.
                                        Kind Regards,
                                        Tom
                                        • TIGT
                                          @Tom
                                          Ensure that the SketchUp Plugins folder AND all of its contents [subfolders/files] have FULL Read/Write security permissions set.
                                          On Windows existing contents typically adopt the settings of their parent.
                                          Properties > Security > Edit... each user/group in the list > FULL... Apply/OK
                                          On a MAC you need to deliberately tell the OS to apply the changes to contents.
                                          On Linux it may be the same...
                                          Also set Sketchup.exe to 'always run as administrator' [if you can] ...
                                          Do you have that .rb file in the named subfolder
                                          C:/Program Files/SketchUp/SketchUp 2013/Plugins/FREDOTOOLS_Dir_12/__loader.rbIf not, then it suggests you had limited permissions and the have not installed the files as you think you have...
                                          • fredo6F
                                            fredo6
                                            @tolson68 said:
                                            Fredo,
                                            Tom,
                                            Strange message. Not sure it is related to your Linux installation.
                                            Could you check that the file __loader.rb contains a single line:
                                            Traductor::Plugin.myplugin('FredoTools').effective_load
                                            Fredo
                                            • 6
                                            • 7
                                            • 23
                                            • 24
                                            • 5 / 24
